Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
Giriş
If the red LED light on the front of the console does not light up when the power is on (and you care about the cosmetics of your system), this guide will allow you to replace the bulb
Parçalar
Hiçbir parça belirtilmedi.
  1. After the top cover of the console  has been removed, focus attention  on the front of the motherboard.  You will see the red LED bulb.
    • After the top cover of the console has been removed, focus attention on the front of the motherboard. You will see the red LED bulb.
    • Coming out of the plastic bulb are two electrodes (they look like small pins). Locate these electrodes/pins. Each of these pins bends downward and sticks through the motherboard through two holes that are side by side.
  2. Nintendo Switch Setleri
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  3. To remove the light, start by  heating up a soldering utensil.  When it is hot, place the tip onto either one of the pin slots so soften the connection between the pin and the board.  Repeat this process on the other pinhole. To remove the light, start by  heating up a soldering utensil.  When it is hot, place the tip onto either one of the pin slots so soften the connection between the pin and the board.  Repeat this process on the other pinhole.
    • To remove the light, start by heating up a soldering utensil. When it is hot, place the tip onto either one of the pin slots so soften the connection between the pin and the board. Repeat this process on the other pinhole.
  4. Wedge a thin screwdriver underneath the LED light, and pull up so that the LED light is facing toward the ceiling. Use pliers on the pins to wiggle and loosen them until they can be removed from the motherboard. Wedge a thin screwdriver underneath the LED light, and pull up so that the LED light is facing toward the ceiling. Use pliers on the pins to wiggle and loosen them until they can be removed from the motherboard.
    • Wedge a thin screwdriver underneath the LED light, and pull up so that the LED light is facing toward the ceiling. Use pliers on the pins to wiggle and loosen them until they can be removed from the motherboard.
  5. You have now removed the light, and a new one is ready to be put into its place. With your new LED light bulb (it should only be rated at 3.4 volts at a maximum), you will stick its two pins through the motherboard, just as the original LED bulb was set up.
    • You have now removed the light, and a new one is ready to be put into its place. With your new LED light bulb (it should only be rated at 3.4 volts at a maximum), you will stick its two pins through the motherboard, just as the original LED bulb was set up.
    • Once the pins are through, and you have positioned the new bulb as the old one was positioned, heat up the area surround the holes and the pins with the soldering iron. Then touch some soldering metal to this hot area. It will form a bond between the pin and the motherboard and allow for electricity to flow and power the bulb.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Benjamin Donnelly
1.128 İtibar
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 10
Son 30 gün: 62
Her zaman: 6,013
