Ana içeriğe geç
Nintendo 64 Metal Plate Replacement
Neye ihtiyacın var
  1. Nintendo 64 Metal Plate Replacement, Top Cover: adım 1, 1 resimden 1.
    • Remove the expansion pack cover by pushing in the tab and pulling out.
  2. Nintendo 64 Metal Plate Replacement: adım 2, 1 resimden 1.
    • If your system uses a jumper pack, the same procedure applies to remove it.
    • A small spoon can be used in place of a spudger.
    • Lever the expansion pack out using a metal spudger.
  3. Nintendo 64 Metal Plate Replacement: adım 3, 1 resimden 1.
    • Remove the six screws on the bottom side indicated in the example with a gamebit head or screwdriver.
  4. Nintendo 64 Metal Plate Replacement: adım 4, 1 resimden 1.
    • Remove the two front feet of the N64.
  5. Nintendo 64 Metal Plate Replacement: adım 5, 1 resimden 1.
    • Rotate to top side up and lift off top cover.
  6. Nintendo 64 Metal Plate Replacement, Metal Plate: adım 6, 2 resimden 1. Nintendo 64 Metal Plate Replacement, Metal Plate: adım 6, 2 resimden 2.
    • Remove the fourteen screws indicated in the example using the larger Phillips screwdriver.
  7. Nintendo 64 Metal Plate Replacement: adım 7, 2 resimden 1. Nintendo 64 Metal Plate Replacement: adım 7, 2 resimden 2.
    • Remove the metal plate indicated in the example by sliding it back and then lifting it up.
  8. Nintendo 64 Metal Plate Replacement: adım 8, 1 resimden 1.
    • Remove the two screws indicated in the example using the smaller Phillips screwdriver.
  9. Nintendo 64 Metal Plate Replacement: adım 9, 1 resimden 1.
    • Remove the screw to the right of the LED light using the larger Phillips screwdriver.
  10. Nintendo 64 Metal Plate Replacement: adım 10, 1 resimden 1.
    • Remove the small metal bracket from the back of the expansion pack slot.
  11. Nintendo 64 Metal Plate Replacement: adım 11, 2 resimden 1. Nintendo 64 Metal Plate Replacement: adım 11, 2 resimden 2.
    • Remove the small metal bracket from the front of the expansion pack slot with the metal spudger.
  12. Nintendo 64 Metal Plate Replacement: adım 12, 2 resimden 1. Nintendo 64 Metal Plate Replacement: adım 12, 2 resimden 2.
    • Remove the small metal bracket behind the expansion slot using the spudger.
  13. Nintendo 64 Metal Plate Replacement: adım 13, 2 resimden 1. Nintendo 64 Metal Plate Replacement: adım 13, 2 resimden 2.
    • Remove the seven screws indicated in the example using the larger Phillips screwdriver.
  14. Nintendo 64 Metal Plate Replacement: adım 14, 1 resimden 1.
    • Lift off and remove the metal plate as indicated in the example.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
LisaF818
143 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 5-4, Regan Fall 2009 Cal Poly, Team 5-4, Regan Fall 2009 üyesi
CPSU-REGAN-F09S5G4
7 Üyeler
15 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 21
Son 30 gün: 61
Her zaman: 11,312
