Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
This guide shows how to remove the metal plate that covers the motherboard.
  1. Remove the expansion pack cover by pushing in the tab and pulling out.
    • Remove the expansion pack cover by pushing in the tab and pulling out.
  2. If your system uses a jumper pack, the same procedure applies to remove it.
    • If your system uses a jumper pack, the same procedure applies to remove it.
    • A small spoon can be used in place of a spudger.
    • Lever the expansion pack out using a metal spudger.
  3. Remove the six screws on the bottom side indicated in the example with a gamebit head or screwdriver.
    • Remove the six screws on the bottom side indicated in the example with a gamebit head or screwdriver.
  4. Remove the two front feet of the N64.
    • Remove the two front feet of the N64.
  5. Rotate to top side up and lift off top cover.
    • Rotate to top side up and lift off top cover.
  6. Remove the fourteen screws indicated in the example using the larger Phillips screwdriver. Remove the fourteen screws indicated in the example using the larger Phillips screwdriver.
    • Remove the fourteen screws indicated in the example using the larger Phillips screwdriver.
  7. Remove the metal plate indicated in the example by sliding it back and then lifting it up. Remove the metal plate indicated in the example by sliding it back and then lifting it up.
    • Remove the metal plate indicated in the example by sliding it back and then lifting it up.
  8. Remove the two screws indicated in the example using the smaller Phillips screwdriver.
    • Remove the two screws indicated in the example using the smaller Phillips screwdriver.
  9. Remove the screw to the right of the LED light using the larger Phillips screwdriver.
    • Remove the screw to the right of the LED light using the larger Phillips screwdriver.
  10. Remove the small metal bracket from the back of the expansion pack slot.
    • Remove the small metal bracket from the back of the expansion pack slot.
  11. Remove the small metal bracket from the front of the expansion pack slot with the metal spudger. Remove the small metal bracket from the front of the expansion pack slot with the metal spudger.
    • Remove the small metal bracket from the front of the expansion pack slot with the metal spudger.
  12. Remove the small metal bracket behind the expansion slot using the spudger. Remove the small metal bracket behind the expansion slot using the spudger.
    • Remove the small metal bracket behind the expansion slot using the spudger.
  13. Remove the seven screws indicated in the example using the larger Phillips screwdriver. Remove the seven screws indicated in the example using the larger Phillips screwdriver.
    • Remove the seven screws indicated in the example using the larger Phillips screwdriver.
  14. Lift off and remove the metal plate as indicated in the example.
    • Lift off and remove the metal plate as indicated in the example.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
LisaF818
131 İtibar
1 Kılavuz yazıldı
Takım
Cal Poly, Team 5-4, Regan Fall 2009 Cal Poly, Team 5-4, Regan Fall 2009 üyesi
CPSU-REGAN-F09S5G4
7 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 45
Her zaman: 9,799
