Ana içeriğe geç
Nintendo 64 Motherboard Replacement
Neye ihtiyacın var
  1. Nintendo 64 Motherboard Replacement, Top Cover: adım 1, 1 resimden 1.
    • Remove the expansion pack cover by pushing in the tab and pulling out.
    FixBot'a Sor
    Yorum Ekle
  2. Nintendo 64 Motherboard Replacement: adım 2, 1 resimden 1.
    • If your system uses a jumper pack, the same procedure applies to remove it.
    • A small spoon can be used in place of a spudger.
    • Lever the expansion pack out using a metal spudger.
    FixBot'a Sor
    Yorum Ekle
  3. Nintendo 64 Motherboard Replacement: adım 3, 1 resimden 1.
    • Remove the six screws on the bottom side indicated in the example with a gamebit head or screwdriver.
    FixBot'a Sor
    Yorum Ekle
  4. Nintendo 64 Motherboard Replacement: adım 4, 1 resimden 1.
    • Remove the two front feet of the N64.
    FixBot'a Sor
    Yorum Ekle
  5. Nintendo 64 Motherboard Replacement: adım 5, 1 resimden 1.
    • Rotate to top side up and lift off top cover.
    FixBot'a Sor
    Yorum Ekle
  6. Nintendo 64 Motherboard Replacement, Metal Plate: adım 6, 2 resimden 1. Nintendo 64 Motherboard Replacement, Metal Plate: adım 6, 2 resimden 2.
    • Remove the fourteen screws indicated in the example using the larger Phillips screwdriver.
    FixBot'a Sor
    Yorum Ekle
  7. Nintendo 64 Motherboard Replacement: adım 7, 2 resimden 1. Nintendo 64 Motherboard Replacement: adım 7, 2 resimden 2.
    • Remove the metal plate indicated in the example by sliding it back and then lifting it up.
    FixBot'a Sor
    Yorum Ekle
  8. Nintendo 64 Motherboard Replacement: adım 8, 1 resimden 1.
    • Remove the two screws indicated in the example using the smaller Phillips screwdriver.
    FixBot'a Sor
    Yorum Ekle
  9. Nintendo 64 Motherboard Replacement: adım 9, 1 resimden 1.
    • Remove the screw to the right of the LED light using the larger Phillips screwdriver.
    FixBot'a Sor
    Yorum Ekle
  10. Nintendo 64 Motherboard Replacement: adım 10, 1 resimden 1.
    • Remove the small metal bracket from the back of the expansion pack slot.
    FixBot'a Sor
    Yorum Ekle
  11. Nintendo 64 Motherboard Replacement: adım 11, 2 resimden 1. Nintendo 64 Motherboard Replacement: adım 11, 2 resimden 2.
    • Remove the small metal bracket from the front of the expansion pack slot with the metal spudger.
    FixBot'a Sor
    Yorum Ekle
  12. Nintendo 64 Motherboard Replacement: adım 12, 2 resimden 1. Nintendo 64 Motherboard Replacement: adım 12, 2 resimden 2.
    • Remove the small metal bracket behind the expansion slot using the spudger.
    FixBot'a Sor
    Yorum Ekle
  13. Nintendo 64 Motherboard Replacement: adım 13, 2 resimden 1. Nintendo 64 Motherboard Replacement: adım 13, 2 resimden 2.
    • Remove the seven screws indicated in the example using the larger Phillips screwdriver.
    FixBot'a Sor
    Yorum Ekle
  14. Nintendo 64 Motherboard Replacement: adım 14, 1 resimden 1.
    • Lift off and remove the metal plate as indicated in the example.
    FixBot'a Sor
    Yorum Ekle
  15. Nintendo 64 Motherboard Replacement, Motherboard: adım 15, 1 resimden 1.
    • Remove the four screws indicated using the #1 Phillips screwdriver.
    FixBot'a Sor
    Yorum Ekle
  16. Nintendo 64 Motherboard Replacement, Motherboard removal: adım 16, 1 resimden 1.
    • Lift up and remove the motherboard.
    FixBot'a Sor
    Yorum Ekle
Sonuç
41 farklı kişi bu kılavuzu tamamladı.
tonymag28
2.309 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 5-4, Regan Fall 2009 Cal Poly, Team 5-4, Regan Fall 2009 üyesi
CPSU-REGAN-F09S5G4
7 Üyeler
20 adet Kılavuz yazıldı
3Kılavuz Yorumları
4.2mm doesn't seem right. When I looked to purchase all I saw was 4.5mm and now that I have one in my hand it seems to fit very precisely on the screws on my N64.
negroslim - Yanıt Paylaş
i got the second comment :whyy:
Sqwerks - Yanıt Paylaş
What are the symptoms of a bad motherboard?
Jon - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 54
Son 30 gün: 304
Her zaman: 72,169
