Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
This guide will show how to replace the Nintendo 64 motherboard.
  1. Remove the expansion pack cover by pushing in the tab and pulling out.
    • Remove the expansion pack cover by pushing in the tab and pulling out.
  2. If your system uses a jumper pack, the same procedure applies to remove it.
    • If your system uses a jumper pack, the same procedure applies to remove it.
    • A small spoon can be used in place of a spudger.
    • Lever the expansion pack out using a metal spudger.
  3. Remove the six screws on the bottom side indicated in the example with a gamebit head or screwdriver.
    • Remove the six screws on the bottom side indicated in the example with a gamebit head or screwdriver.
  4. Remove the two front feet of the N64.
    • Remove the two front feet of the N64.
  5. Rotate to top side up and lift off top cover.
    • Rotate to top side up and lift off top cover.
  6. Remove the fourteen screws indicated in the example using the larger Phillips screwdriver. Remove the fourteen screws indicated in the example using the larger Phillips screwdriver.
    • Remove the fourteen screws indicated in the example using the larger Phillips screwdriver.
    I’m not entirely certain if it's a common difference, but my nintendo 64 doesn’t have fourteen screws, but rather, 8 screws, and instead of 3 heat sinks, it only has the one separate heat sink on the chip close to the memory expansion pack. additionally, aside from the 6 screws closest to the expansion pack, the two other screws are held on by nuts under the metal piece.
    Avery Duncan - Yanıt
  7. Remove the metal plate indicated in the example by sliding it back and then lifting it up. Remove the metal plate indicated in the example by sliding it back and then lifting it up.
    • Remove the metal plate indicated in the example by sliding it back and then lifting it up.
  8. Remove the two screws indicated in the example using the smaller Phillips screwdriver.
    • Remove the two screws indicated in the example using the smaller Phillips screwdriver.
  9. Remove the screw to the right of the LED light using the larger Phillips screwdriver.
    • Remove the screw to the right of the LED light using the larger Phillips screwdriver.
  10. Remove the small metal bracket from the back of the expansion pack slot.
    • Remove the small metal bracket from the back of the expansion pack slot.
  11. Remove the small metal bracket from the front of the expansion pack slot with the metal spudger. Remove the small metal bracket from the front of the expansion pack slot with the metal spudger.
    • Remove the small metal bracket from the front of the expansion pack slot with the metal spudger.
  12. Remove the small metal bracket behind the expansion slot using the spudger. Remove the small metal bracket behind the expansion slot using the spudger.
    • Remove the small metal bracket behind the expansion slot using the spudger.
  13. Remove the seven screws indicated in the example using the larger Phillips screwdriver. Remove the seven screws indicated in the example using the larger Phillips screwdriver.
    • Remove the seven screws indicated in the example using the larger Phillips screwdriver.
    The two screws next to the cartridge slot are longer
    Michael - Yanıt
  14. Lift off and remove the metal plate as indicated in the example.
    • Lift off and remove the metal plate as indicated in the example.
  15. Remove the four screws indicated using the #1 Phillips screwdriver.
    • Remove the four screws indicated using the #1 Phillips screwdriver.
  16. Lift up and remove the motherboard.
    • Lift up and remove the motherboard.
Sonuç
30 farklı kişi bu kılavuzu tamamladı.
tonymag28
1.879 İtibar
3 adet Kılavuz yazıldı
Takım
Cal Poly, Team 5-4, Regan Fall 2009 Cal Poly, Team 5-4, Regan Fall 2009 üyesi
CPSU-REGAN-F09S5G4
7 Üyeler
6 adet Kılavuz yazıldı
Bir Yorum
4.2mm doesn't seem right. When I looked to purchase all I saw was 4.5mm and now that I have one in my hand it seems to fit very precisely on the screws on my N64.
negroslim - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 41
Son 30 gün: 268
Her zaman: 51,971
