Ana içeriğe geç
Nintendo DS Back Panel Replacement
Neye ihtiyacın var
  1. Nintendo DS Back Panel Replacement, Battery: adım 1, 3 resimden 1. Nintendo DS Back Panel Replacement, Battery: adım 1, 3 resimden 2. Nintendo DS Back Panel Replacement, Battery: adım 1, 3 resimden 3.
    • Remove the cartridge from the console.
    • Use a Phillips #00 Screwdriver to remove the screw securing the battery door to the rear case.
    • Remove the battery door.
    • In the images, it shows that the fixer is using a flathead screwdriver. This flathead screwdriver will work just like the Phillips #00 Screwdriver.
    FixBot'a Sor
    Yorum Ekle
  2. Nintendo DS Back Panel Replacement: adım 2, 1 resimden 1.
    • Use a plastic opening tool or spudger to pry out the battery from the bottom. If a plastic opening tool or spudger isn't available, your fingernails may work.
    FixBot'a Sor
    Yorum Ekle
  3. Nintendo DS Back Panel Replacement: adım 3, 1 resimden 1.
    • Remove the battery from the Nintendo DS.
    FixBot'a Sor
    Yorum Ekle
  4. Nintendo DS Back Panel Replacement, Back Panel: adım 4, 1 resimden 1.
    • Remove the seven 6.4mm Y00 screws located on the back.
    • If your DS has a lanyard attached to it, you can remove it to make the process of opening the top-left screw easier.
    FixBot'a Sor
    Yorum Ekle
  5. Nintendo DS Back Panel Replacement: adım 5, 3 resimden 1. Nintendo DS Back Panel Replacement: adım 5, 3 resimden 2. Nintendo DS Back Panel Replacement: adım 5, 3 resimden 3.
    • With your hands, pry the back panel off the main case.
    • Separate the back from the front, and set it aside.
    FixBot'a Sor
    Yorum Ekle
Sonuç
20 farklı kişi bu kılavuzu tamamladı.
dnguye26
758 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 18-3, Maness Fall 2009 Cal Poly, Team 18-3, Maness Fall 2009 üyesi
CPSU-MANESS-F09S18G3
4 Üyeler
31 adet Kılavuz yazıldı
2Kılavuz Yorumları
Where do I get a nintendo DS gamepak?
Kayla Maison - Yanıt Paylaş
Kayla Maison , a gamepak is simply a GBA game.
Bob - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 62
Son 30 gün: 195
Her zaman: 21,372
