Ana içeriğe geç
Nintendo DS Back Panel Replacement
Neye ihtiyacın var
  1. Nintendo DS Back Panel Replacement, Battery: adım 1, 3 resimden 1. Nintendo DS Back Panel Replacement, Battery: adım 1, 3 resimden 2. Nintendo DS Back Panel Replacement, Battery: adım 1, 3 resimden 3.
    • Remove the cartridge from the console.
    • Use a Phillips #00 Screwdriver to remove the screw securing the battery door to the rear case.
    • Remove the battery door.
    • In the images, it shows that the fixer is using a flathead screwdriver. This flathead screwdriver will work just like the Phillips #00 Screwdriver.
  2. Nintendo DS Back Panel Replacement: adım 2, 1 resimden 1.
    • Use a plastic opening tool or spudger to pry out the battery from the bottom. If a plastic opening tool or spudger isn't available, your fingernails may work.
  3. Nintendo DS Back Panel Replacement: adım 3, 1 resimden 1.
    • Remove the battery from the Nintendo DS.
  4. Nintendo DS Back Panel Replacement, Back Panel: adım 4, 1 resimden 1.
    • Remove the seven 6.4mm Y00 screws located on the back.
    • If your DS has a lanyard attached to it, you can remove it to make the process of opening the top-left screw easier.
  5. Nintendo DS Back Panel Replacement: adım 5, 3 resimden 1. Nintendo DS Back Panel Replacement: adım 5, 3 resimden 2. Nintendo DS Back Panel Replacement: adım 5, 3 resimden 3.
    • With your hands, pry the back panel off the main case.
    • Separate the back from the front, and set it aside.
    If some of your screws spin free but can’t be removed, it maybe that the screw posts have separated from the shell.
    This makes separating the back panel more difficult, but it will still work.
    The plastic used for the original silver nds may be the most prone to the UV damage that causes the plastic to become brittle.
    Del Riordan - Yanıt
Sonuç
17 farklı kişi bu kılavuzu tamamladı.
dnguye26
694 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 18-3, Maness Fall 2009 Cal Poly, Team 18-3, Maness Fall 2009 üyesi
CPSU-MANESS-F09S18G3
4 Üyeler
28 adet Kılavuz yazıldı
2 Yorum
Where do I get a nintendo DS gamepak?
Kayla Maison - Yanıt
Kayla Maison , a gamepak is simply a GBA game.
Bob - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 29
Son 30 gün: 108
Her zaman: 17,582
