Giriş
Removing the back panel is simple, provided you have the correct screwdriver. Nintendo uses a special Tri-point bit for the case, be sure you have one of these before disassembling!
Neye ihtiyacın var
Remove the cartridge from the console.
Use a Phillips #00 Screwdriver to remove the screw securing the battery door to the rear case.
Remove the battery door.
With your hands, pry the back panel off the main case.
Separate the back from the front, and set it aside.
If some of your screws spin free but can’t be removed, it maybe that the screw posts have separated from the shell.
This makes separating the back panel more difficult, but it will still work.
The plastic used for the original silver nds may be the most prone to the UV damage that causes the plastic to become brittle.
18 farklı kişi bu kılavuzu tamamladı.
2Kılavuz Yorumları
Where do I get a nintendo DS gamepak?
