Giriş
Removing the back panel is simple, provided you have the correct screwdriver. Nintendo uses a special Tri-wing bit for the case, be sure you have one of these before disassembling!
Parçalar
Hiçbir parça belirtilmedi.
Remove the cartridge from the console.
Use a Phillips #00 Screwdriver to remove the screw securing the battery door to the rear case.
Remove the battery door.
17 farklı kişi bu kılavuzu tamamladı.
2 Yorum
Where do I get a nintendo DS gamepak?
