Ana içeriğe geç
Nintendo DS Lite Battery Replacement
Neye ihtiyacın var
  1. Nintendo DS Lite Battery Replacement, Battery: adım 1, 2 resimden 1. Nintendo DS Lite Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Unscrew the Phillips screw securing the battery cover to the lower case.
    • The screw remains captive to the battery cover.
    • Pry the battery cover upward with a spudger or fingernail, and lift out of the lower case.
    FixBot'a Sor
    Yorum Ekle
  2. Nintendo DS Lite Battery Replacement: adım 2, 1 resimden 1.
    • Wedge the edge of a spudger in between the side of the battery and the lower case housing and pry upward to dislodge the battery.
    • Remove the battery from the DS Lite.
    FixBot'a Sor
    Yorum Ekle
Sonuç
52 farklı kişi bu kılavuzu tamamladı.
Matthew Newsom
42.811 İtibar
67 adet Kılavuz yazıldı
6Kılavuz Yorumları
Can you describe the type of screw and captive washer ?
Cornel Paraschiv - Yanıt Paylaş
Thank you.
i just ordered a new battery as I already got a new power cord & it won’t charge at all.
Hoping new battery does the trick.
Thanks again.
T. Kellogg
Tamela Kellogg - Yanıt Paylaş
Thanks but will a dsi battery work
Zach - Yanıt Paylaş
While a very late reply, someone else may find this useful.
In short, no. Not at all. The DS Lite Battery I own (Original) Is listed as
USG-003
3.7v
1000 mAH
3.7 Wh
Where as the DSi battery I own (Again, an original straight from my console) is listed as:
TWL-003
3.7v
840 mAH
3.1 Wh
While the same voltage and a slight difference in capacity, the DSi Battery is slightly longer and slimmer in width to the DS/DS Lite Battery and you will need to find a battery suited for the DS/DS Lite you're using. Many places will sell these batteries but do your research as not all of these are created equal.
kaelowynlee - Yanıt Paylaş
My battery cover won’t come off.
Jake - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 18
Son 7 gün: 194
Son 30 gün: 846
Her zaman: 76,486
