Giriş
Replace the power switch on the Nintendo DS Lite.
Neye ihtiyacın var
Unscrew the Phillips screw securing the battery cover to the lower case.
Pry the battery cover upward with a spudger or fingernail, and lift out of the lower case.
Insert the edge of a spudger in between the lower and upper case near the top right corner of the DS Lite.
Carefully run the spudger along the right edge of the DS Lite, creating an opening in the process.
Continue running the spudger along the backside of the DS Lite until the majority of the lower case has been separated from the upper case.
Bu adımda kullanılan alet:Tweezers$4.99
Use a pair of tweezers to carefully remove the power switch.
20 farklı kişi bu kılavuzu tamamladı.
4Kılavuz Yorumları
What about replacing the soldered portion of the switch? The tip that moves with the plastic to turn the handheld on/off has broken off of mine
Yeah, what he said..
If the plastic tab has broken off of the soldered part of the switch, you could try to glue a replacement tab onto the internal sliding mechanism, but more likely you’ll end up gumming up the works and effectively destroying the part, but then again it’s not as if you have a lot to lose by trying.
Alternatively you’ll need to get a replacement switch and desolder the broken part then installing the new part. Be careful that you don’t get the iron in contact with the top of the switch as that may melt the moving parts together, potentially necessitating another replacement.
Emily H -
Just desolder the old faulty switch and solder in your new replacment.
