Ana içeriğe geç
Nintendo DS Lite Top Screen Replacement
Neye ihtiyacın var
  1. Nintendo DS Lite Top Screen Replacement, Nintendo DS Lite Battery Disconnect: adım 1, 1 resimden 1.
    • Place your device upside down and locate the battery compartment.
    • Find the Phillips head screw securing the battery cover in the bottom right hand corner of the device.
    • Loosen the screw enough to remove the battery cover but leave the screw in the cover for reassembly.
    • Use only a Phillips screwdriver to remove screw.
    take out gameboy slot too!
    pollytintop - Yanıt
  2. Nintendo DS Lite Top Screen Replacement: adım 2, 1 resimden 1.
    • Slowly remove the battery cover with the iFixit opening tool.
    • Make sure to remove the cover carefully to keep from losing Phillips screw in the cover. It will be needed for reassembly.
  3. Nintendo DS Lite Top Screen Replacement: adım 3, 2 resimden 1. Nintendo DS Lite Top Screen Replacement: adım 3, 2 resimden 2.
    • Use the iFixit opening tool to carefully pry the battery out of the case.
    • After the old battery is removed replace it with a new battery facing the same direction as when the cover was opened.
    • For some devices, you may be able to remove the battery by flipping the DS over and letting the battery fall into your hand.
  4. Nintendo DS Lite Top Screen Replacement, Disassembling Nintendo DS Lite Bottom Case: adım 4, 1 resimden 1.
    • Remove the following seven screws that secure the lower case to the DS Lite:
    • Three silver tri-wing screws (5mm long)
    • One black tri-wing screw (4mm)
    • Two gold Phillips screws (4mm)
    • One silver Phillips screw (3mm)
    • Do not remove the silver PH screw (3mm) in the battery compartment yet. It holds the main PCB in place.
    Remove the Tri-Wing screws from the DS cartridge port area and the battery bay.
    Matt - Yanıt
    They left out of the tool section the Triwing screwdriver, a security tool used on most Nintendo game systems. There are 4 Trihead screws holding the case together and 3 Phillips head screws.
    ABCellars - Yanıt
    2 are not philip heads
    roemio do carmo lobo - Yanıt
    I actually have Tri-Wing screws on mine!! You can't open the unit up unless you have the proper tools!
    Jon Fukumoto - Yanıt
    why do they use tri-wing!?!
    Bountofee - Yanıt
  5. Nintendo DS Lite Top Screen Replacement: adım 5, 1 resimden 1.
    • On the front edge of the Nintendo DS between the headphone jack plug and volume controls remove the plastic insert (or cartridge) from the lower slot (Slot 2).
  6. Nintendo DS Lite Top Screen Replacement: adım 6, 2 resimden 1. Nintendo DS Lite Top Screen Replacement: adım 6, 2 resimden 2.
    • Flip the unit over so that it is facing right-side up.
    • Use a spudger to pry open the gap between the bottom case and the front panel. Work all the way around the case until the panel is free.
    • Avoid touching the L and R shoulder buttons, because they easily detach and are difficult to reassemble. Keep the bottom case flat against your workbench to help hold the shoulder buttons in place.
  7. Nintendo DS Lite Top Screen Replacement: adım 7, 3 resimden 1. Nintendo DS Lite Top Screen Replacement: adım 7, 3 resimden 2. Nintendo DS Lite Top Screen Replacement: adım 7, 3 resimden 3.
    • Carefully separate the two pieces by hand.
    • The two shoulder buttons are made up of three pieces -- the plastic button, a pin, and a spring. If they accidentally pop out while you are working, study the picture and make sure you put the spring in the correct position.
    • When reassembling the cover, make sure that the power switch caver on the bottom case is in the off (down) position to avoid breakage.
  8. Dikkatli ol: adımlar 8-11 yapım altında olarak işaretlenen bir kılavuzdan alınmıştır.
    Nintendo DS Lite Top Screen Replacement, Motherboard: adım 8, 2 resimden 1. Nintendo DS Lite Top Screen Replacement, Motherboard: adım 8, 2 resimden 2.
    • Locate the two screws that attach the logic board to the device.
    • Unscrew the two Phillips head screws.
  9. Nintendo DS Lite Top Screen Replacement: adım 9, 1 resimden 1.
    • With a plastic opening tool, gently separate the logic board from the device base.
    • The ribbon cable and two wires are still connected to the logic board.
    • The buttons may fall out, but can easily be put back in place.
  10. Nintendo DS Lite Top Screen Replacement: adım 10, 3 resimden 1. Nintendo DS Lite Top Screen Replacement: adım 10, 3 resimden 2. Nintendo DS Lite Top Screen Replacement: adım 10, 3 resimden 3.
    • Flip the logic board over so that the touch screen is facing up.
    • Using metal tweezers, carefully disconnect the other ribbon cable that connects the touch screen with the logic board.
  11. Nintendo DS Lite Top Screen Replacement: adım 11, 1 resimden 1.
    • Using one finger nail or the plastic opening tool, carefully lift the brown securing flap of the connector. Then disconnect the ribbon cable that connects the logic board to the upper screen.
  12. Nintendo DS Lite Top Screen Replacement, Top Screen: adım 12, 2 resimden 1. Nintendo DS Lite Top Screen Replacement, Top Screen: adım 12, 2 resimden 2.
    • Remove the two Phillips-head screws that hold the hinge in place.
    • Open the system up (just like if you were about to use it normally).
  13. Nintendo DS Lite Top Screen Replacement: adım 13, 2 resimden 1. Nintendo DS Lite Top Screen Replacement: adım 13, 2 resimden 2.
    • After opening it, carefully unhinge them from each other by sliding the bottom piece to the left and the top piece to the right.
    • Be aware that you can pinch wires while doing this, so don't yank it apart.
  14. Nintendo DS Lite Top Screen Replacement: adım 14, 1 resimden 1.
    • Using a push pin, remove the four rubber bumpers located at the corners of the top screen.
    • After removing the LEDs and pulling apart the hinge, remove the round hinge shaft. This should be in the top screen piece.
  15. Nintendo DS Lite Top Screen Replacement: adım 15, 2 resimden 1. Nintendo DS Lite Top Screen Replacement: adım 15, 2 resimden 2.
    • Unscrew the four Phillips-head screws and remove the top panel.
    • Be careful not to damage the wires and the ribbon cable.
    Be careful when pulling the top screen apart. The tabs holding the screen together may bend and you won't be able to get the back cover back on. Try sliding the back of the screen forward and then pull it apart after removing screws
    Vinnesia League - Yanıt
  16. Nintendo DS Lite Top Screen Replacement: adım 16, 2 resimden 1. Nintendo DS Lite Top Screen Replacement: adım 16, 2 resimden 2.
    • Carefully remove the two speakers and the green wireless card from the top panel.
  17. Nintendo DS Lite Top Screen Replacement: adım 17, 1 resimden 1.
    • Remove the screen by orienting it face down and pushing up on the screen from underneath.
    • Don't press on the screen too hard, or you may crack the screen.
  18. Nintendo DS Lite Top Screen Replacement: adım 18, 1 resimden 1.
    • Carefully slide the ribbon cable through the clip.
    • Be careful not to damage the ribbon cable by pulling to hard or creasing it.
    Soldering time :(
    chuahh - Yanıt
Sonuç
21 farklı kişi bu kılavuzu tamamladı.
Brittany K
1.484 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 16-30, Maness Winter 2010 Cal Poly, Team 16-30, Maness Winter 2010 üyesi
CPSU-MANESS-W10S16G30
4 Üyeler
24 adet Kılavuz yazıldı
6 Yorum
This guide is extremely poor. Please do not follow if you wish to repair your DS top screen. The steps finish before you get the end probably due to the fact the author blatantly doesn't want to mention the fact you need to solder the speakers on.
There should also be more warnings about the power switch broke on both the examples I tried to repair.
Neil Baker - Yanıt
iFixit will be creating new DS Lite guides very soon. Give the authors credit though, because it's not easy to create a full set of repair guides!
Matthew Newsom -
no im with neil this is just bad
Brian Girnus - Yanıt
Yeah, this guide really sucks. I ripped one of the tips of the orange tapes trying to remove the old screen. I don’t think it’ll work now. Thanks a whole lot, @%^$$@$#.
MR J - Yanıt
Honestly, thats a mistake on your end.
HeronEgret -
I'd rather turn the DS lite into a gameboy macro
BadassSunset - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 11
Son 7 gün: 100
Son 30 gün: 442
Her zaman: 41,333
