Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
This guide has been updated by iFixit staff! Read the new, official guide here.
Replacing the top screen on the Nintendo DS Lite.
Neye ihtiyacın var
Place your device upside down and locate the battery compartment.
Find the Phillips head screw securing the battery cover in the bottom right hand corner of the device.
Remove the following seven screws that secure the lower case to the DS Lite:
Three silver tri-wing screws (5mm long)
One black tri-wing screw (4mm)
Two gold Phillips screws (4mm)
One silver Phillips screw (3mm)
Do not remove the silver PH screw (3mm) in the battery compartment yet. It holds the main PCB in place.
Flip the unit over so that it is facing right-side up.
Use a spudger to pry open the gap between the bottom case and the front panel. Work all the way around the case until the panel is free.
Avoid touching the L and R shoulder buttons, because they easily detach and are difficult to reassemble. Keep the bottom case flat against your workbench to help hold the shoulder buttons in place.
Adım 8 Motherboard
Dikkatli ol: adımlar 8-11 yapım altında olarak işaretlenen bir kılavuzdan alınmıştır.
Locate the two screws that attach the logic board to the device.
Unscrew the two Phillips head screws.
Remove the two Phillips-head screws that hold the hinge in place.
Open the system up (just like if you were about to use it normally).
21 farklı kişi bu kılavuzu tamamladı.
6 Yorum
This guide is extremely poor. Please do not follow if you wish to repair your DS top screen. The steps finish before you get the end probably due to the fact the author blatantly doesn't want to mention the fact you need to solder the speakers on.
There should also be more warnings about the power switch broke on both the examples I tried to repair.
iFixit will be creating new DS Lite guides very soon. Give the authors credit though, because it's not easy to create a full set of repair guides!
no im with neil this is just bad
Yeah, this guide really sucks. I ripped one of the tips of the orange tapes trying to remove the old screen. I don’t think it’ll work now. Thanks a whole lot, @%^$$@$#.
Honestly, thats a mistake on your end.
