Ana içeriğe geç
Giriş
This is a guide that teaches how to replace a Nintendo DS motherboard also known as a circuit board.
The Nintendo DS is a video game console released by Nintendo proposing two screens working in tandem with wireless connectivity, and an integrated microphone.
The main circuit board holds and makes all communication between components of the device possible. Therefore, whenever the communication between the functioning components takes longer than expected or there is no communication, replacing the motherboard is a necessity.
The removal of the main motherboard of the DS is essential to access the screens and to replace other imperatives.
The replacement could be done in 10 simple steps.
  1. Remove the cartridge from the console. Use a Phillips #00 Screwdriver to remove the screw securing the battery door to the rear case. Remove the battery door.
    • Remove the cartridge from the console.
    • Use a Phillips #00 Screwdriver to remove the screw securing the battery door to the rear case.
    • Remove the battery door.
  2. Use a plastic opening tool or spudger to pry out the battery from the bottom. If a plastic open tool or spudger isn't available, your fingernails may work.
    • Use a plastic opening tool or spudger to pry out the battery from the bottom. If a plastic open tool or spudger isn't available, your fingernails may work.
  3. Remove the battery from the Nintendo DS.
    • Remove the battery from the Nintendo DS.
  4. Remove the seven Y00 screws located on the back.
    • Remove the seven Y00 screws located on the back.
    • It might be helpful to remove the strap from the hole to access the top left screw.
  5. With your hands, pry the back panel off the main case. Separate the back from the front, and set it aside. Separate the back from the front, and set it aside.
    • With your hands, pry the back panel off the main case.
    • Separate the back from the front, and set it aside.
    If some of your screws spin free but can’t be removed, it maybe that the screw posts have separated from the shell.
    This makes separating the back panel more difficult, but it will still work.
    The plastic used for the original silver nds may be the most prone to the UV damage that causes the plastic to become brittle.
    Del Riordan - Yanıt
  6. Using a Phillips #00 screwdriver, remove the four screws on the circuit board.
    • Using a Phillips #00 screwdriver, remove the four screws on the circuit board.
    • Be careful NOT to slip with the screwdriver, you can damage the circuit board!
  7. Unlock the two large ribbon cables by moving the black clip up. Carefully pull the ribbon cables down and out with your fingers. Do not use pliers to pull the cables, as they can be damaged easily.
    • Unlock the two large ribbon cables by moving the black clip up.
    • Carefully pull the ribbon cables down and out with your fingers.
    • Do not use pliers to pull the cables, as they can be damaged easily.
    Benutze für die nächsten Schritte besser einen Spudger und keine Pinzette,
    sonst läufst du Gefahr eines der Kabel oder die Platine selbst zu beschädigen.
    Better use a Spudger, not a Tweezer for the next Steps.
    That minimize the risk to demolish one of the wires or the mainboard himself.
    Christian - Yanıt
    That’s what i did but it didn’t work
    TrequanBlake - Yanıt
  8. Locate the two small ribbon cables, beneath the rightmost large ribbon cable. Slide the locks for the small ribbon cables down to the side, and remove the cables.
    • Locate the two small ribbon cables, beneath the rightmost large ribbon cable.
    • Slide the locks for the small ribbon cables down to the side, and remove the cables.
    • It may be useful to use tweezers to remove the small ribbon cables.
    • Be careful not to damage the delicate ribbon cables.
  9. Locate the Wifi antenna pigtail connector. Remove the antenna by grasping it at the head with tweezers. Using a slight rocking motion, pull up to dislodge the connector.
    • Locate the Wifi antenna pigtail connector.
    • Remove the antenna by grasping it at the head with tweezers. Using a slight rocking motion, pull up to dislodge the connector.
  10. Feed the ribbon cables through the opening on the board.
    • Feed the ribbon cables through the opening on the board.
    • Pull up and remove the circuit board, and set it aside.
Sonuç
15 farklı kişi bu kılavuzu tamamladı.
kingdesmond
1.859 İtibar
1 Kılavuz yazıldı
Takım
Cal Poly, Team 18-3, Maness Fall 2009 Cal Poly, Team 18-3, Maness Fall 2009 üyesi
CPSU-MANESS-F09S18G3
4 Üyeler
20 adet Kılavuz yazıldı
Bir Yorum
This was really helpful. Thank you!
Jess Anderson - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 21
Son 30 gün: 97
Her zaman: 22,964
