Giriş
Use this guide to replace the lower case assembly, including the trigger buttons, SD slot, and stylus holder.
Neye ihtiyacın var
Unscrew the two Phillips screws securing the battery cover to the lower case.
Grasp the battery cover and lift it out of the lower case.
Using a spudger tool (or your fingernail), lift up the battery from the top.
Grasp the battery and remove it from the DSi.
Two screws are hidden underneath two rubber feet highlighted in red.
Use the tip of a spudger to pry the rubber feet out of the lower case.
One of the feet did break on me, tweezers came in handy for picking it out
I unfolded and sharpened a paperclip. You can use that to stab and hook the rubber without tearing it, as the rubber is thick enough to reseal when reinserted.
Remove the following screws securing the lower case to the body of the DSi:
Six 5.2 mm Phillips #00 screws.
One 2.7 mm Phillips #00 screw.
Impossible d'enlever les vises… trop serré! comment faire?
i can't get the screw by the gamecard slot out, PH#00 is too small and PH#0 is too big
same problem here. maybe try a JIS?
Insert the spudger in between the lower casing and lower panel near the top right corner of the DSi.
Carefully run the spudger along the edge of the outer casing, creating an opening between the body and the casing.
Continue running the spudger around the body of the DSi until the majority of the lower case has been separated.
8 farklı kişi bu kılavuzu tamamladı.
