Ana içeriğe geç
Nintendo DSi XL Power Button Replacement
Neye ihtiyacın var
  1. Nintendo DSi XL Power Button Replacement, Battery: adım 1, 2 resimden 1. Nintendo DSi XL Power Button Replacement, Battery: adım 1, 2 resimden 2.
    • Remove the two Phillips screws securing the battery cover to the back of the handheld console.
    • Lift the battery cover off the back of the DSi XL.
  2. Nintendo DSi XL Power Button Replacement: adım 2, 1 resimden 1.
    • Lift the battery from the DSi XL.
  3. Nintendo DSi XL Power Button Replacement, Lower Case: adım 3, 3 resimden 1. Nintendo DSi XL Power Button Replacement, Lower Case: adım 3, 3 resimden 2. Nintendo DSi XL Power Button Replacement, Lower Case: adım 3, 3 resimden 3.
    • Remove the four rubber screw covers on the lower case by prying them up with a push pin.
  4. Nintendo DSi XL Power Button Replacement: adım 4, 1 resimden 1.
    • Remove the following seven Phillips screws that secure the lower case to the rest of the DSi XL:
    • Four silver 5.3 mm screws
    • Two black 5.3 mm screws
    • One black 2.5 mm screw
  5. Nintendo DSi XL Power Button Replacement: adım 5, 3 resimden 1. Nintendo DSi XL Power Button Replacement: adım 5, 3 resimden 2. Nintendo DSi XL Power Button Replacement: adım 5, 3 resimden 3.
    • Turn the DSi XL over, and open the display.
    • Insert a spudger between the upper and lower case at the bottom left corner of the DSi.
    • Slide the spudger along the bottom edge of the upper case to release the latches securing the upper case to the lower case.
  6. Nintendo DSi XL Power Button Replacement: adım 6, 2 resimden 1. Nintendo DSi XL Power Button Replacement: adım 6, 2 resimden 2.
    • Close the display and turn the DSi XL over.
    • Lift the lower case from the front edge.
    • Rotate the lower case away from the DSi.
    • The lower case cannot be completely removed yet, since it is still connected to the motherboard.
  7. Nintendo DSi XL Power Button Replacement: adım 7, 2 resimden 1. Nintendo DSi XL Power Button Replacement: adım 7, 2 resimden 2.
    • Using a spudger, pry the SD card/right shoulder button connector off its socket.
    • Pry the volume button/left shoulder button connector off its socket on the motherboard with a spudger.
  8. Nintendo DSi XL Power Button Replacement, Power Board: adım 8, 2 resimden 1. Nintendo DSi XL Power Button Replacement, Power Board: adım 8, 2 resimden 2.
    • Using the flat end of a spudger, flip up the retaining flap on the ZIF connector for the D-pad/power button cable.
    • With the pointed end of the spudger, pull the D-pad/power button cable from its connector on the motherboard.
  9. Nintendo DSi XL Power Button Replacement: adım 9, 1 resimden 1.
    • Using the flat end of the spudger, carefully pry the battery cable out of its socket on the motherboard.
    • Use caution, as the wires are very fragile and could come out of the connector if pulled on too hard.
  10. Nintendo DSi XL Power Button Replacement: adım 10, 2 resimden 1. Nintendo DSi XL Power Button Replacement: adım 10, 2 resimden 2.
    • Remove the seven 2.5 mm silver screws securing the power board to the upper case.
    • Lift the power board off the upper case.
  11. Nintendo DSi XL Power Button Replacement, Power Button: adım 11, 2 resimden 1. Nintendo DSi XL Power Button Replacement, Power Button: adım 11, 2 resimden 2.
    • Lift the rubber pad off the back of the power button.
    • Open the display slightly and push the power button up through the upper case.
    • Remove the power button from the handheld console.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Brett Hartt
129.899 İtibar
143 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
121 Üyeler
19.674 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 45
Her zaman: 8,649
