Ana içeriğe geç
Nintendo DSi XL Rear Bezel Replacement
Neye ihtiyacın var
  1. Nintendo DSi XL Rear Bezel Replacement, Rear Bezel: adım 1, 3 resimden 1. Nintendo DSi XL Rear Bezel Replacement, Rear Bezel: adım 1, 3 resimden 2. Nintendo DSi XL Rear Bezel Replacement, Rear Bezel: adım 1, 3 resimden 3.
    • Use a push pin to remove the four plastic screw covers on the front bezel.
  2. Nintendo DSi XL Rear Bezel Replacement: adım 2, 1 resimden 1.
    • Remove four Phillips screws securing the front bezel to the rear bezel.
  3. Nintendo DSi XL Rear Bezel Replacement: adım 3, 2 resimden 1. Nintendo DSi XL Rear Bezel Replacement: adım 3, 2 resimden 2.
    • Using two hands, gently slide the rear bezel upwards.
    • The rear bezel will move only about 2 mm.
  4. Nintendo DSi XL Rear Bezel Replacement: adım 4, 2 resimden 1. Nintendo DSi XL Rear Bezel Replacement: adım 4, 2 resimden 2.
    • Insert a spudger into the gap between the front and rear bezel
    • Rotate the spudger away from the DSi XL, prying the two bezels apart.
  5. Nintendo DSi XL Rear Bezel Replacement: adım 5, 1 resimden 1.
    • In the same manner as described above, continue prying along the top edge of the front and rear bezels.
  6. Nintendo DSi XL Rear Bezel Replacement: adım 6, 1 resimden 1.
    • Separate the rear bezel from the front bezel.
    • Do not attempt to completely remove the rear bezel yet. It is still attached to the front bezel by the rear-facing camera.
  7. Nintendo DSi XL Rear Bezel Replacement: adım 7, 1 resimden 1.
    • Use the flat end of a spudger to pry the rear camera off the rear bezel.
    • Remove the rear bezel.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Matthew Newsom
40.884 İtibar
67 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 48
Her zaman: 5,371
