Ana içeriğe geç
Nintendo DSi XL Stylus Housing Replacement
Neye ihtiyacın var
  1. Nintendo DSi XL Stylus Housing Replacement, Battery: adım 1, 2 resimden 1. Nintendo DSi XL Stylus Housing Replacement, Battery: adım 1, 2 resimden 2.
    • Remove the two Phillips screws securing the battery cover to the back of the handheld console.
    • Lift the battery cover off the back of the DSi XL.
  2. Nintendo DSi XL Stylus Housing Replacement: adım 2, 1 resimden 1.
    • Lift the battery from the DSi XL.
  3. Nintendo DSi XL Stylus Housing Replacement, Lower Case: adım 3, 3 resimden 1. Nintendo DSi XL Stylus Housing Replacement, Lower Case: adım 3, 3 resimden 2. Nintendo DSi XL Stylus Housing Replacement, Lower Case: adım 3, 3 resimden 3.
    • Remove the four rubber screw covers on the lower case by prying them up with a push pin.
  4. Nintendo DSi XL Stylus Housing Replacement: adım 4, 1 resimden 1.
    • Remove the following seven Phillips screws that secure the lower case to the rest of the DSi XL:
    • Four silver 5.3 mm screws
    • Two black 5.3 mm screws
    • One black 2.5 mm screw
  5. Nintendo DSi XL Stylus Housing Replacement: adım 5, 3 resimden 1. Nintendo DSi XL Stylus Housing Replacement: adım 5, 3 resimden 2. Nintendo DSi XL Stylus Housing Replacement: adım 5, 3 resimden 3.
    • Turn the DSi XL over, and open the display.
    • Insert a spudger between the upper and lower case at the bottom left corner of the DSi.
    • Slide the spudger along the bottom edge of the upper case to release the latches securing the upper case to the lower case.
  6. Nintendo DSi XL Stylus Housing Replacement: adım 6, 2 resimden 1. Nintendo DSi XL Stylus Housing Replacement: adım 6, 2 resimden 2.
    • Close the display and turn the DSi XL over.
    • Lift the lower case from the front edge.
    • Rotate the lower case away from the DSi.
    • The lower case cannot be completely removed yet, since it is still connected to the motherboard.
  7. Nintendo DSi XL Stylus Housing Replacement: adım 7, 2 resimden 1. Nintendo DSi XL Stylus Housing Replacement: adım 7, 2 resimden 2.
    • Using a spudger, pry the SD card/right shoulder button connector off its socket.
    • Pry the volume button/left shoulder button connector off its socket on the motherboard with a spudger.
  8. Nintendo DSi XL Stylus Housing Replacement, Right Shoulder Button: adım 8, 3 resimden 1. Nintendo DSi XL Stylus Housing Replacement, Right Shoulder Button: adım 8, 3 resimden 2. Nintendo DSi XL Stylus Housing Replacement, Right Shoulder Button: adım 8, 3 resimden 3.
    • Remove the two gold 4.0 mm Phillips screws securing the right shoulder button assembly to the back case.
    • Lift the right shoulder button assembly from the back case.
    • The components of the right shoulder button assembly:
    • Right shoulder button
    • Shoulder button spring
    • Retaining pin
    • Right shoulder button holding panel
  9. Nintendo DSi XL Stylus Housing Replacement, Stylus Housing: adım 9, 1 resimden 1.
    • Remove the stylus from its housing on the right side of the DSi XL.
  10. Nintendo DSi XL Stylus Housing Replacement: adım 10, 3 resimden 1. Nintendo DSi XL Stylus Housing Replacement: adım 10, 3 resimden 2. Nintendo DSi XL Stylus Housing Replacement: adım 10, 3 resimden 3.
    • Remove the three 4 mm gold Phillips screws securing the stylus housing to the lower case.
    • Using a spudger, lift the stylus housing off the lower case.
    • Remove the stylus housing from the handheld console.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Brett Hartt
129.899 İtibar
143 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
121 Üyeler
19.674 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 36
Her zaman: 8,005
