Ana içeriğe geç
Nintendo DSi XL Touchscreen Replacement
Neye ihtiyacın var
  1. Nintendo DSi XL Touchscreen Replacement, Battery: adım 1, 2 resimden 1. Nintendo DSi XL Touchscreen Replacement, Battery: adım 1, 2 resimden 2.
    • Remove the two Phillips screws securing the battery cover to the back of the handheld console.
    • Lift the battery cover off the back of the DSi XL.
    FixBot'a Sor
  2. Nintendo DSi XL Touchscreen Replacement: adım 2, 1 resimden 1.
    • Lift the battery from the DSi XL.
    FixBot'a Sor
  3. Nintendo DSi XL Touchscreen Replacement, Lower Case: adım 3, 3 resimden 1. Nintendo DSi XL Touchscreen Replacement, Lower Case: adım 3, 3 resimden 2. Nintendo DSi XL Touchscreen Replacement, Lower Case: adım 3, 3 resimden 3.
    • Remove the four rubber screw covers on the lower case by prying them up with a push pin.
    FixBot'a Sor
  4. Nintendo DSi XL Touchscreen Replacement: adım 4, 1 resimden 1.
    • Remove the following seven Phillips screws that secure the lower case to the rest of the DSi XL:
    • Four silver 5.3 mm screws
    • Two black 5.3 mm screws
    • One black 2.5 mm screw
    FixBot'a Sor
  5. Nintendo DSi XL Touchscreen Replacement: adım 5, 3 resimden 1. Nintendo DSi XL Touchscreen Replacement: adım 5, 3 resimden 2. Nintendo DSi XL Touchscreen Replacement: adım 5, 3 resimden 3.
    • Turn the DSi XL over, and open the display.
    • Insert a spudger between the upper and lower case at the bottom left corner of the DSi.
    • Slide the spudger along the bottom edge of the upper case to release the latches securing the upper case to the lower case.
    FixBot'a Sor
  6. Nintendo DSi XL Touchscreen Replacement: adım 6, 2 resimden 1. Nintendo DSi XL Touchscreen Replacement: adım 6, 2 resimden 2.
    • Close the display and turn the DSi XL over.
    • Lift the lower case from the front edge.
    • Rotate the lower case away from the DSi.
    • The lower case cannot be completely removed yet, since it is still connected to the motherboard.
    FixBot'a Sor
  7. Nintendo DSi XL Touchscreen Replacement: adım 7, 2 resimden 1. Nintendo DSi XL Touchscreen Replacement: adım 7, 2 resimden 2.
    • Using a spudger, pry the SD card/right shoulder button connector off its socket.
    • Pry the volume button/left shoulder button connector off its socket on the motherboard with a spudger.
    FixBot'a Sor
  8. Nintendo DSi XL Touchscreen Replacement, Wi-Fi Board: adım 8, 2 resimden 1. Nintendo DSi XL Touchscreen Replacement, Wi-Fi Board: adım 8, 2 resimden 2.
    • Lift the Wi-Fi board up off its socket on the motherboard.
    • Do not attempt to completely remove the Wi-Fi board yet. It is attached to the motherboard by an antenna cable.
    FixBot'a Sor
  9. Nintendo DSi XL Touchscreen Replacement: adım 9, 1 resimden 1.
    • Use a spudger to pry the Wi-Fi cable off its socket on the underside of the Wi-Fi board.
    FixBot'a Sor
  10. Nintendo DSi XL Touchscreen Replacement, Motherboard: adım 10, 1 resimden 1.
    • Use a spudger to pry the microphone cable off the motherboard.
    • Pry from underneath the cable.
    FixBot'a Sor
  11. Nintendo DSi XL Touchscreen Replacement: adım 11, 2 resimden 1. Nintendo DSi XL Touchscreen Replacement: adım 11, 2 resimden 2.
    • Using the flat end of a spudger, flip up the retaining flap on the camera ribbon ZIF connector.
    • Use the pointed end of a spudger to pull the camera ribbon from the ZIF connector.
    FixBot'a Sor
  12. Nintendo DSi XL Touchscreen Replacement: adım 12, 2 resimden 1. Nintendo DSi XL Touchscreen Replacement: adım 12, 2 resimden 2.
    • Using the flat end of a spudger, flip up the retaining flap on the touchscreen cable ZIF connector.
    • With the pointed end of the spudger, pull the touchscreen cable from its connector on the motherboard.
    FixBot'a Sor
  13. Nintendo DSi XL Touchscreen Replacement: adım 13, 2 resimden 1. Nintendo DSi XL Touchscreen Replacement: adım 13, 2 resimden 2.
    • Using the flat end of a spudger, flip up the retaining flap on the backlight cable ZIF connector.
    • With the pointed end of the spudger, pull the backlight cable from its connector on the motherboard.
    FixBot'a Sor
  14. Nintendo DSi XL Touchscreen Replacement: adım 14, 2 resimden 1. Nintendo DSi XL Touchscreen Replacement: adım 14, 2 resimden 2.
    • Using the flat end of a spudger, flip up the retaining flap on the lower display data cable ZIF connector.
    • With the pointed end of the spudger, pull the lower display data cable from its connector on the motherboard.
    FixBot'a Sor
  15. Nintendo DSi XL Touchscreen Replacement: adım 15, 2 resimden 1. Nintendo DSi XL Touchscreen Replacement: adım 15, 2 resimden 2.
    • Using the flat end of a spudger, flip up the retaining flap on the ZIF connector for the D-Pad/power button cable.
    • With the pointed end of the spudger, pull the D-Pad/power button cable from its connector on the motherboard.
    FixBot'a Sor
  16. Nintendo DSi XL Touchscreen Replacement: adım 16, 1 resimden 1.
    • Using the flat end of the spudger, pry the battery cable up off its socket on the motherboard.
    FixBot'a Sor
  17. Nintendo DSi XL Touchscreen Replacement: adım 17, 1 resimden 1.
    • Remove the screws securing the motherboard to the upper case:
    • A single 2.5 mm silver Phillips screw
    • Four 3.7 mm black Phillips screws
    FixBot'a Sor
  18. Nintendo DSi XL Touchscreen Replacement: adım 18, 1 resimden 1.
    • Deroute the microphone and antenna cables through the slot in the motherboard.
    FixBot'a Sor
  19. Nintendo DSi XL Touchscreen Replacement: adım 19, 2 resimden 1. Nintendo DSi XL Touchscreen Replacement: adım 19, 2 resimden 2.
    • Rotate the motherboard off the lower case.
    • The motherboard cannot be completely removed yet. It is still attached by the upper LCD's display data ribbon cable.
    FixBot'a Sor
  20. Nintendo DSi XL Touchscreen Replacement: adım 20, 2 resimden 1. Nintendo DSi XL Touchscreen Replacement: adım 20, 2 resimden 2.
    • Using the flat end of a spudger, flip up the retaining flap on the upper display data cable ZIF connector.
    • With the pointed end of the spudger, pull the upper display data cable from its connector on the underside of the motherboard.
    • The motherboard is now free from the upper case.
    FixBot'a Sor
  21. Nintendo DSi XL Touchscreen Replacement, Lower Display Assembly: adım 21, 2 resimden 1. Nintendo DSi XL Touchscreen Replacement, Lower Display Assembly: adım 21, 2 resimden 2.
    • With the console still upside-down, open the DSi XL slightly.
    • Push the lower display away from the upper case.
    • Remove the lower display from the DSi XL.
    FixBot'a Sor
  22. Nintendo DSi XL Touchscreen Replacement, Lower LCD: adım 22, 2 resimden 1. Nintendo DSi XL Touchscreen Replacement, Lower LCD: adım 22, 2 resimden 2.
    • Insert a spudger between the touchscreen and top right corner of the display.
    • Slide the spudger down the right side of the display to free the edge of the touchscreen.
    FixBot'a Sor
  23. Nintendo DSi XL Touchscreen Replacement: adım 23, 2 resimden 1. Nintendo DSi XL Touchscreen Replacement: adım 23, 2 resimden 2.
    • Continue around the bottom right corner of the display with the spudger.
    • Slide the spudger along the bottom edge of the touchscreen to separate it from the display.
    FixBot'a Sor
  24. Nintendo DSi XL Touchscreen Replacement: adım 24, 2 resimden 1. Nintendo DSi XL Touchscreen Replacement: adım 24, 2 resimden 2.
    • Continue around the bottom left corner of the display with a spudger.
    • Slide the spudger along the left edge of the touchscreen to remove it from the display.
    FixBot'a Sor
  25. Nintendo DSi XL Touchscreen Replacement: adım 25, 2 resimden 1. Nintendo DSi XL Touchscreen Replacement: adım 25, 2 resimden 2.
    • With three sides freed, remove the touchscreen from the lower display.
    FixBot'a Sor
Sonuç
20 farklı kişi bu kılavuzu tamamladı.
David Hodson
156.208 İtibar
127 adet Kılavuz yazıldı
4Kılavuz Yorumları
Great tutorial, I completely missed the fact that the lower screen is TWO screens: the touchscreen and the proper screen. Nailed it!!
luissebastianangeles - Yanıt Paylaş
thankyou! <3
Zenn22 - Yanıt Paylaş
Step 16 = whole socket came off the motherboard with the least amount of effort. Tried soldering new contacts but too fine. Device now only good for parts.
Reese Banister - Yanıt Paylaş
Be super careful with p10 and p18 retention clips. If these come out, you are up the creek without a paddle.
Aaron Newman - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 12
Son 7 gün: 91
Son 30 gün: 495
Her zaman: 55,948
