Aletler
Hiçbir alete gerek yok.
  1. Remove the two Phillips screws securing the battery cover to the back of the handheld console. Lift the battery cover off the back of the DSi XL.
    • Remove the two Phillips screws securing the battery cover to the back of the handheld console.
    • Lift the battery cover off the back of the DSi XL.
  2. Lift the battery from the DSi XL.
    • Lift the battery from the DSi XL.
  3. Remove the four rubber screw covers on the lower case by prying them up with a push pin. Remove the four rubber screw covers on the lower case by prying them up with a push pin. Remove the four rubber screw covers on the lower case by prying them up with a push pin.
    • Remove the four rubber screw covers on the lower case by prying them up with a push pin.
  4. Remove the following seven Phillips screws that secure the lower case to the rest of the DSi XL:
    • Remove the following seven Phillips screws that secure the lower case to the rest of the DSi XL:
    • Four silver 5.3 mm screws
    • Two black 5.3 mm screws
    • One black 2.5 mm screw
  5. Turn the DSi XL over, and open the display. Insert a spudger between the upper and lower case at the bottom left corner of the DSi. Slide the spudger along the bottom edge of the upper case to release the latches securing the upper case to the lower case.
    • Turn the DSi XL over, and open the display.
    • Insert a spudger between the upper and lower case at the bottom left corner of the DSi.
    • Slide the spudger along the bottom edge of the upper case to release the latches securing the upper case to the lower case.
  6. Close the display and turn the DSi XL over. Lift the lower case from the front edge.
    • Close the display and turn the DSi XL over.
    • Lift the lower case from the front edge.
    • Rotate the lower case away from the DSi.
    • The lower case cannot be completely removed yet, since it is still connected to the motherboard.
  7. Using a spudger, pry the SD card/right shoulder button connector off its socket. Pry the volume button/left shoulder button connector off its socket on the motherboard with a spudger.
    • Using a spudger, pry the SD card/right shoulder button connector off its socket.
    • Pry the volume button/left shoulder button connector off its socket on the motherboard with a spudger.
  8. Use a spudger to pry the microphone cable off the motherboard.
    • Use a spudger to pry the microphone cable off the motherboard.
    • Pry from underneath the cable.
  9. Using the flat end of a spudger, flip up the retaining flap on the camera ribbon ZIF connector. Use the pointed end of a spudger to pull the camera ribbon from the ZIF connector.
    • Using the flat end of a spudger, flip up the retaining flap on the camera ribbon ZIF connector.
    • Use the pointed end of a spudger to pull the camera ribbon from the ZIF connector.
  10. Using the flat end of a spudger, flip up the retaining flap on the touchscreen cable ZIF connector. With the pointed end of the spudger, pull the touchscreen cable from its connector on the motherboard.
    • Using the flat end of a spudger, flip up the retaining flap on the touchscreen cable ZIF connector.
    • With the pointed end of the spudger, pull the touchscreen cable from its connector on the motherboard.
  11. Pro Tech Toolkit içeren veya $100tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  12. Using the flat end of a spudger, flip up the retaining flap on the backlight cable ZIF connector. With the pointed end of the spudger, pull the backlight cable from its connector on the motherboard.
    • Using the flat end of a spudger, flip up the retaining flap on the backlight cable ZIF connector.
    • With the pointed end of the spudger, pull the backlight cable from its connector on the motherboard.
  13. Using the flat end of a spudger, flip up the retaining flap on the lower display data cable ZIF connector. With the pointed end of the spudger, pull the lower display data cable from its connector on the motherboard.
    • Using the flat end of a spudger, flip up the retaining flap on the lower display data cable ZIF connector.
    • With the pointed end of the spudger, pull the lower display data cable from its connector on the motherboard.
  14. Using the flat end of a spudger, flip up the retaining flap on the ZIF connector for the D-Pad/power button cable. With the pointed end of the spudger, pull the D-Pad/power button cable from its connector on the motherboard.
    • Using the flat end of a spudger, flip up the retaining flap on the ZIF connector for the D-Pad/power button cable.
    • With the pointed end of the spudger, pull the D-Pad/power button cable from its connector on the motherboard.
  15. Using the flat end of the spudger, pry the battery cable up off its socket on the motherboard.
    • Using the flat end of the spudger, pry the battery cable up off its socket on the motherboard.
  16. Remove the screws securing the motherboard to the upper case:
    • Remove the screws securing the motherboard to the upper case:
    • A single 2.5 mm silver Phillips screw
    • Four 3.7 mm black Phillips screws
  17. Deroute the microphone and antenna cables through the slot in the motherboard.
    • Deroute the microphone and antenna cables through the slot in the motherboard.
  18. Rotate the motherboard off the lower case. The motherboard cannot be completely removed yet. It is still attached by the upper LCD's display data ribbon cable.
    • Rotate the motherboard off the lower case.
    • The motherboard cannot be completely removed yet. It is still attached by the upper LCD's display data ribbon cable.
  19. Using the flat end of a spudger, flip up the retaining flap on the upper display data cable ZIF connector. With the pointed end of the spudger, pull the upper display data cable from its connector on the underside of the motherboard.
    • Using the flat end of a spudger, flip up the retaining flap on the upper display data cable ZIF connector.
    • With the pointed end of the spudger, pull the upper display data cable from its connector on the underside of the motherboard.
    • The motherboard is now free from the upper case.
  20. With the console still upside-down, open the DSi XL slightly. Push the lower display away from the upper case.
    • With the console still upside-down, open the DSi XL slightly.
    • Push the lower display away from the upper case.
    • Remove the lower display from the DSi XL.
  21. Turn the DSi XL over and open the display. When re-assembling the device, be sure to re-install the ABXY and Start/Select buttons, as they are likely to fall out once the handheld console is turned over. Use a pushpin to remove the four plastic screw covers on the front bezel.
    • Turn the DSi XL over and open the display.
    • When re-assembling the device, be sure to re-install the ABXY and Start/Select buttons, as they are likely to fall out once the handheld console is turned over.
    • Use a pushpin to remove the four plastic screw covers on the front bezel.
  22. Remove the four 3.5 mm silver Phillips screws securing the rear bezel to the front bezel.
    • Remove the four 3.5 mm silver Phillips screws securing the rear bezel to the front bezel.
  23. Using two hands, gently slide the rear bezel upwards. The rear bezel will move only about 2 mm.
    • Using two hands, gently slide the rear bezel upwards.
    • The rear bezel will move only about 2 mm.
  24. Insert a spudger into the gap between the front and rear bezel. Rotate the spudger away from the DSi XL, prying the two bezels apart.
    • Insert a spudger into the gap between the front and rear bezel.
    • Rotate the spudger away from the DSi XL, prying the two bezels apart.
  25. In the same manner as described above, continue prying along the top edge of the front and rear bezels. In the same manner as described above, continue prying along the top edge of the front and rear bezels.
    • In the same manner as described above, continue prying along the top edge of the front and rear bezels.
  26. Separate the rear bezel from the front bezel.
    • Separate the rear bezel from the front bezel.
    • Do not attempt to completely remove the rear bezel yet. It is still attached to the front bezel by the rear-facing camera.
  27. Using the flat end of a spudger, pry the rear camera off the rear bezel.
    • Using the flat end of a spudger, pry the rear camera off the rear bezel.
    • Remove the rear bezel.
  28. Remove the Phillips screw holding the metal securing bracket in place. Lift the metal bracket off the camera.
    • Remove the Phillips screw holding the metal securing bracket in place.
    • Lift the metal bracket off the camera.
  29. Lift the Wi-Fi antenna off the front display bezel. De-route the Wi-Fi antenna cable from its grooves at the bottom of the front display bezel.
    • Lift the Wi-Fi antenna off the front display bezel.
    • De-route the Wi-Fi antenna cable from its grooves at the bottom of the front display bezel.
  30. Pull the Wi-Fi antenna cable through the right hinge connecting the front bezel and upper case. Use the pointed end of a spudger to guide the connector at the end of the Wi-Fi antenna cable through the hinge. To replace the antenna, use a pair of tweezers to guide the connector through the hinge.
    • Pull the Wi-Fi antenna cable through the right hinge connecting the front bezel and upper case.
    • Use the pointed end of a spudger to guide the connector at the end of the Wi-Fi antenna cable through the hinge.
    • To replace the antenna, use a pair of tweezers to guide the connector through the hinge.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Brett Hartt
110.637 İtibar
138 adet Kılavuz yazıldı
Takım
iFixit iFixit üyesi
Community
108 Üyeler
8.319 adet Kılavuz yazıldı
Bir Yorum
Hello,
i was wondering if the antenna from the dsi xl was the same as the one from the normal dsi?
Gilles de Looze - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 4
Son 30 Gün: 11
Her zaman: 4,409
