Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Unscrew the six 13 mm screws with the Philips screwdriver.
Lift the controller back plate straight off of the controller then set aside.
Remove all plastic buttons. Clean the buttons and controller with soap and water.
Inspect each rubber pad for tears or cracks and making note of any tears.
Clean all pads with rubbing alcohol; focus on cleaning the black conductive circles on the underside of the pads.
Ensure that all 91% isopropyl alcohol has evaporated. If necessary perform any soldering away from the area in which you cleaned the controller.
Re-solder any loose wires on the circuit board.
Glue the cord onto the circuit board to prevent future loosening of the wires.
Leave slack on both sides and allow glue to harden.
Reverse steps from 6 through to 2 to reassemble controller.
Before replacing screws make sure the controller back fits tightly to the controller face.
If needed trim excess glue from around the cord to ensure a good fit.
Plug in your repaired controller and try all buttons and actions to test controller function and responsiveness
6 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
Hi There,
Just wondering if you knew “where” I could purchase a special set of silicone buttons for a wireless Nintendo NES controller? The buttons are sticking and when I remove the cover, the silicone buttons were stripped and no longer functional. I know how to replace all of the parts - just not sure where I can actually find the part that I need.
I am not sure if you know what the “NES wireless controller” looks like “internally” but it has 4 buttons together - not just 2 like the original NES controller. The silicone button assembly looks very similar to the silicone button assembly of the “controller buttons” portion (or the arrows portion that actually allows you to “move” when playing a game.
Any assistance you could provide for me to find the right part to fix my son’s controller would be GREATLY APPRECIATED !!
Thank you
Jeff
