Giriş
If the springs work properly but are not properly mounted to the cartridge tray, follow these instructions.
Neye ihtiyacın var
Remove the six 13.25mm Phillips screws on the bottom of the game console with a #2.5 flathead screwdriver.
Flip the game console right side up and take off the top by pulling it up and away from the rest of the device with your hands.
Remove the two silver 17.45mm Phillips screws from the cartridge tray using a Phillips head #2 screwdriver.
Remove the two bronze 13.25mm Phillips screws from the cartridge tray using a Phillips head #2 screwdriver.
Slide the cartridge tray toward you, away from the 72-PIN connector, and off the motherboard assembly.
Use your fingernail to squeeze down on one side of the spring and reposition the spring back on to the plastic nipple attached to the smaller part of the game cartridge frame.
4 farklı kişi bu kılavuzu tamamladı.
