Ana içeriğe geç
Nintendo Game Boy Advance SP Battery Replacement
Neye ihtiyacın var
  1. Nintendo Game Boy Advance SP Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Use a standard Phillips #00 screwdriver to loosen the 4 mm screw that keeps the battery cover attached to the device.
  2. Nintendo Game Boy Advance SP Battery Replacement: adım 2, 1 resimden 1.
    • Lift the battery cover up and remove it from the device.
    • The screw will remain attached to the battery cover because of Nintendo's design.
  3. Nintendo Game Boy Advance SP Battery Replacement: adım 3, 1 resimden 1.
    • Use your fingers or a plastic opening tool to remove the battery from the device.
    • Caution: Please exercise caution when handling the battery. If it appears to be swelling or damaged at all it is considered a fire hazard.
Sonuç
For reassembly, follow the instructions in reverse order.
31 farklı kişi bu kılavuzu tamamladı.
Rocco Lattanzio
1.009 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 17-22, Forte Winter 2013 Cal Poly, Team 17-22, Forte Winter 2013 üyesi
CPSU-FORTE-W13S17G22
4 Üyeler
41 adet Kılavuz yazıldı
3 Yorum
This task is not very easy, its easy.
Very easy: Does not require opening device.
Easy: Requires minimal disassembly and requires a few tools like a Philips or flat-head screwdriver.
This however requires opening device.
Santi12008 - Yanıt
Why so pedantic?
keegan clow -
Thanks for yout guideline. I settle in 5 minutes.
aam9999 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 47
Son 7 gün: 189
Son 30 gün: 716
Her zaman: 74,074
