Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Use a standard Phillips #00 screwdriver to loosen the 4 mm screw that keeps the battery cover attached to the device.
Lift the battery cover up and remove it from the device.
Use your fingers or a plastic opening tool to remove the battery from the device.
30 farklı kişi bu kılavuzu tamamladı.
2 Yorum
This task is not very easy, its easy.
Very easy: Does not require opening device.
Easy: Requires minimal disassembly and requires a few tools like a Philips or flat-head screwdriver.
This however requires opening device.
