Ana içeriğe geç
Nintendo Game Boy Advance SP Brightness Switch Replacement
Neye ihtiyacın var
  1. Nintendo Game Boy Advance SP Brightness Switch Replacement, Battery: adım 1, 1 resimden 1.
    • Use a standard Phillips #00 screwdriver to loosen the 4 mm screw that keeps the battery cover attached to the device.
  2. Nintendo Game Boy Advance SP Brightness Switch Replacement: adım 2, 1 resimden 1.
    • Lift the battery cover up and remove it from the device.
    • The screw will remain attached to the battery cover because of Nintendo's design.
  3. Nintendo Game Boy Advance SP Brightness Switch Replacement: adım 3, 1 resimden 1.
    • Use your fingers or a plastic opening tool to remove the battery from the device.
    • Caution: Please exercise caution when handling the battery. If it appears to be swelling or damaged at all it is considered a fire hazard.
  4. Nintendo Game Boy Advance SP Brightness Switch Replacement, Back Cover: adım 4, 2 resimden 1. Nintendo Game Boy Advance SP Brightness Switch Replacement, Back Cover: adım 4, 2 resimden 2.
    • Remove four 6.5 mm screws from the corners of the back cover using a tri-point Y00 screwdriver.
    • Remove two 4.6mm screws from the top-center and bottom-center of the device using a tri-point Y00 screwdriver.
  5. Nintendo Game Boy Advance SP Brightness Switch Replacement: adım 5, 1 resimden 1.
    • Lift the back cover off of the device.
    • Potential for device damage: These inner components are vulnerable to static electricity. Exercise caution when handling these next steps to prevent damaging the device.
    • Look out for the power switch that can fall out when taking the back cover off.
  6. Nintendo Game Boy Advance SP Brightness Switch Replacement, Motherboard: adım 6, 1 resimden 1.
    • Using a Phillips #00 screwdriver, remove the three Phillips #00 4 mm long screws that hold the motherboard to the button panel.
  7. Nintendo Game Boy Advance SP Brightness Switch Replacement: adım 7, 1 resimden 1.
    • Be careful not to tear the ribbon cable that's connected to the screen. If you tear it, games will not appear on the device's screen!
    • Flip the motherboard up and rest it on the other half of the device, so that the back of the buttons are visible as seen in the picture.
  8. Nintendo Game Boy Advance SP Brightness Switch Replacement, Brightness Switch: adım 8, 1 resimden 1.
    • With your fingers, lift the track pad out off the brightness switch.
    • Keep the track pad clean. A dirty or dusty track pad will lead to the brightness switch not working when you press it.
  9. Nintendo Game Boy Advance SP Brightness Switch Replacement: adım 9, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Using tweezers, lift the brightness switch out of the Game Boy Advance SP.
Sonuç
15 farklı kişi bu kılavuzu tamamladı.
DJ Pantone
1.924 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 17-22, Forte Winter 2013 Cal Poly, Team 17-22, Forte Winter 2013 üyesi
CPSU-FORTE-W13S17G22
4 Üyeler
39 adet Kılavuz yazıldı
Bir Yorum
Thank you so much
sherzadcemil - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 33
Son 30 gün: 122
Her zaman: 19,094
