Giriş
The brightness switch is the circular button with a sun symbol engraved into it. The brightness switch is located at the top of the button panel.
Parçalar
Use a standard Phillips #00 screwdriver to loosen the 4 mm screw that keeps the battery cover attached to the device.
Remove four 6.5 mm screws from the corners of the back cover using a tri-point Y00 screwdriver.
Remove two 4.6mm screws from the top-center and bottom-center of the device using a tri-point Y00 screwdriver.
Using a Phillips #00 screwdriver, remove the three Phillips #00 4 mm long screws that hold the motherboard to the button panel.
With your fingers, lift the track pad out off the brightness switch.
12 farklı kişi bu kılavuzu tamamladı.
