Ana içeriğe geç
Nintendo Game Boy Advance SP Power Switch Cover Replacement
Arşivlenmiş Kılavuz
Bu kılavuz sadece arşivsel amaçlarla muhafaza edilmiştir. Onarımınızı gerçekleştirmek için kılavuzun güncel halini kullanın.
Neye ihtiyacın var
  1. Nintendo Game Boy Advance SP Power Switch Cover Replacement, Prepare your Game Boy for disassembly: adım 1, 3 resimden 1. Nintendo Game Boy Advance SP Power Switch Cover Replacement, Prepare your Game Boy for disassembly: adım 1, 3 resimden 2. Nintendo Game Boy Advance SP Power Switch Cover Replacement, Prepare your Game Boy for disassembly: adım 1, 3 resimden 3.
    • Slide the power switch to the OFF position and unplug any cables.
    • If you have a game cartridge in, remove it.
  2. Nintendo Game Boy Advance SP Power Switch Cover Replacement, Remove the battery cover: adım 2, 2 resimden 1. Nintendo Game Boy Advance SP Power Switch Cover Replacement, Remove the battery cover: adım 2, 2 resimden 2.
    • Use a JIS 00 screwdriver to loosen the captive screw securing the battery cover.
    • You can try to use a non-iFixit Phillips driver in a pinch, but you risk damaging or stripping the screw. Push down firmly on the driver and twist slowly.
  3. Nintendo Game Boy Advance SP Power Switch Cover Replacement: adım 3, 3 resimden 1. Nintendo Game Boy Advance SP Power Switch Cover Replacement: adım 3, 3 resimden 2. Nintendo Game Boy Advance SP Power Switch Cover Replacement: adım 3, 3 resimden 3.
    • Lift the edge of the cover near the screw and remove the cover.
    • During reassembly, hook the tabs on the bottom edge of the cover into their slots and lay the cover into place.
  4. Nintendo Game Boy Advance SP Power Switch Cover Replacement, Remove the battery: adım 4, 3 resimden 1. Nintendo Game Boy Advance SP Power Switch Cover Replacement, Remove the battery: adım 4, 3 resimden 2. Nintendo Game Boy Advance SP Power Switch Cover Replacement, Remove the battery: adım 4, 3 resimden 3.
    • Use your finger to lift the battery by the tab on its left edge, then remove it.
    • During reassembly:
    • Never reuse a deformed or damaged battery—it's a fire hazard. Replace it with a new battery.
    • Your replacement battery may come with a plastic enclosure that slides over the battery.
    • Insert the edge of the battery with contacts at a slight downward angle—aligning the contacts with their prongs in the recess—and press the battery into place.
  5. Nintendo Game Boy Advance SP Power Switch Cover Replacement, Remove the bottom shell: adım 5, 2 resimden 1. Nintendo Game Boy Advance SP Power Switch Cover Replacement, Remove the bottom shell: adım 5, 2 resimden 2.
    • Use a tri‑point Y0 screwdriver to remove the six screws securing the bottom shell:
    • Four 6.3 mm‑long recessed screws
    • Two 4.6 mm‑long screws
  6. Nintendo Game Boy Advance SP Power Switch Cover Replacement: adım 6, 2 resimden 1. Nintendo Game Boy Advance SP Power Switch Cover Replacement: adım 6, 2 resimden 2.
    • Lift the bottom shell straight up and remove it.
  7. Nintendo Game Boy Advance SP Power Switch Cover Replacement, Power Switch Cover: adım 7, 2 resimden 1. Nintendo Game Boy Advance SP Power Switch Cover Replacement, Power Switch Cover: adım 7, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Lift the power switch cover away from the left side of the device using your fingers or tweezers.
Sonuç
17 farklı kişi bu kılavuzu tamamladı.
DJ Pantone
1.992 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 17-22, Forte Winter 2013 Cal Poly, Team 17-22, Forte Winter 2013 üyesi
CPSU-FORTE-W13S17G22
4 Üyeler
32 adet Kılavuz yazıldı
3Kılavuz Yorumları
This doesn't explain anything about how to replace the switch
Michael - Yanıt
Maybe the guide was for replacing the power switch cover?
Dominick Scheible - Yanıt
where to buy invidual y00,y0 or y1 bit?
Coola Nillon - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 51
Her zaman: 22,614
