Ana içeriğe geç
Nintendo GameCube Controller Directional Pad Replacement
Neye ihtiyacın var
  1. Nintendo GameCube Controller Directional Pad Replacement, Back Panel: adım 1, 1 resimden 1.
    • Place the controller (buttons down) on a solid surface.
    • Remove the six 9.2mm Tri-wing Y0 screws that hold the back panel in place.
  2. Nintendo GameCube Controller Directional Pad Replacement: adım 2, 1 resimden 1.
    • Gently lift the back panel up, separating it from the front panel.
    • Some of the buttons may fall out if they are knocked around.
  3. Nintendo GameCube Controller Directional Pad Replacement, Z Button: adım 3, 2 resimden 1. Nintendo GameCube Controller Directional Pad Replacement, Z Button: adım 3, 2 resimden 2.
    • Grab the Z-button by the peg with tweezers and lift it out of the controller.
    • During re-assembly, make sure the plastic rim and spring fit into the slot provided, or else the case will not shut.
  4. Nintendo GameCube Controller Directional Pad Replacement, Circuit Board: adım 4, 1 resimden 1.
    • Carefully unhook the cable that is looped around the peg.
  5. Nintendo GameCube Controller Directional Pad Replacement: adım 5, 1 resimden 1.
    • Lift the circuit board out of the controller.
    • Do not grab the rumble motor to lift the circuit board as shown in the picture. It will in many cases just remove the rumble motor. Instead, grab the edges of the board.
  6. Nintendo GameCube Controller Directional Pad Replacement, Directional Pad: adım 6, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Remove the rubber backing with tweezers.
  7. Nintendo GameCube Controller Directional Pad Replacement: adım 7, 1 resimden 1.
    • Use tweezers to grab the center peg of the directional pad and lift it out of its socket.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Sean Michel
2.600 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 19-44, Regan Winter 2013 Cal Poly, Team 19-44, Regan Winter 2013 üyesi
CPSU-REGAN-W13S19G44
4 Üyeler
32 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 16
Son 30 gün: 43
Her zaman: 7,383
