Ana içeriğe geç
Nintendo GameCube Controller Z Button Replacement
Neye ihtiyacın var
  1. Nintendo GameCube Controller Z Button Replacement, Back Panel: adım 1, 1 resimden 1.
    • Place the controller (buttons down) on a solid surface.
    • Remove the six 9.2mm Tri-wing Y0 screws that hold the back panel in place.
  2. Nintendo GameCube Controller Z Button Replacement: adım 2, 1 resimden 1.
    • Gently lift the back panel up, separating it from the front panel.
    • Some of the buttons may fall out if they are knocked around.
  3. Nintendo GameCube Controller Z Button Replacement, Z Button: adım 3, 2 resimden 1. Nintendo GameCube Controller Z Button Replacement, Z Button: adım 3, 2 resimden 2.
    • Grab the Z-button by the peg with tweezers and lift it out of the controller.
    • During re-assembly, make sure the plastic rim and spring fit into the slot provided, or else the case will not shut.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Sean Michel
2.600 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 19-44, Regan Winter 2013 Cal Poly, Team 19-44, Regan Winter 2013 üyesi
CPSU-REGAN-W13S19G44
4 Üyeler
32 adet Kılavuz yazıldı
6Kılavuz Yorumları
My z button presses down and makes the click, but it does not actually send any input to the controller. How do you fix this?
Augustine Park - Yanıt
So how do you put it back in like the replacement because I have a controller I'm working with a junker my Friend gave me and I'm trying to fix it the z button doesn't work here is a pic
Justin Sebastian - Yanıt
My bad no pic it's a pelican wireless controller
Justin Sebastian -
How do you change the spring? I have replacement z buttons just no spring for them…
Gaf Epar - Yanıt
Does that silver bar on the bottom of the Z button supposed to be there? My Z button does not have that, is it important for the button to have that?
Kevin Alaniz - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 27
Son 30 gün: 109
Her zaman: 21,201
