Ana içeriğe geç
Nintendo GameCube Fan replacement for cleaning
Neye ihtiyacın var
  1. Nintendo GameCube Fan replacement for cleaning, Top Case: adım 1, 3 resimden 1. Nintendo GameCube Fan replacement for cleaning, Top Case: adım 1, 3 resimden 2. Nintendo GameCube Fan replacement for cleaning, Top Case: adım 1, 3 resimden 3.
    • Turn over the Gamecube so that the bottom side is facing up.
    • Use the 4.5 mm Gamebit screwdriver to remove all four screws.
    FixBot'a Sor
    Yorum Ekle
  2. Nintendo GameCube Fan replacement for cleaning: adım 2, 3 resimden 1. Nintendo GameCube Fan replacement for cleaning: adım 2, 3 resimden 2. Nintendo GameCube Fan replacement for cleaning: adım 2, 3 resimden 3.
    • With the bottom side of the GameCube facing upward and the screws removed, carefully pull the outer shell of the unit away from the top half.
    • Move the GameCube so that the inside is facing upwards.
    FixBot'a Sor
    Yorum Ekle
  3. Nintendo GameCube Fan replacement for cleaning, Fan: adım 3, 2 resimden 1. Nintendo GameCube Fan replacement for cleaning, Fan: adım 3, 2 resimden 2.
    • Using a Phillips #2 screwdriver, remove the two screws (circled in red) attaching the fan assembly to the unit.
    • Carefully disconnect the fan connector from the socket, as depicted in the second picture.
    • The controller connector panel can be gently pulled out of the main unit and laid down, as depicted. This is not strictly required, but may provide more maneuverability inside the case.
    • Make sure to not pull out the wires while removing the fan. Doing so may damage the connector wire or the PCB.
    FixBot'a Sor
    Yorum Ekle
  4. Nintendo GameCube Fan replacement for cleaning: adım 4, 2 resimden 1. Nintendo GameCube Fan replacement for cleaning: adım 4, 2 resimden 2.
    • Once the fan is removed, use compressed air to clean the dust off of the fan blades.
    • It is highly recommended that you use a toothpick to prevent the fan blades from moving while cleaning. This will prevent accidental damage to the fans motor.
    FixBot'a Sor
    Yorum Ekle
Sonuç
14 farklı kişi bu kılavuzu tamamladı.
dcarlin
399 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-2, Maness Fall 2009 Cal Poly, Team 6-2, Maness Fall 2009 üyesi
CPSU-MANESS-F09S6G2
4 Üyeler
45 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 56
Son 30 gün: 184
Her zaman: 42,809
