Ana içeriğe geç
Nintendo GameCube Front and Back Panel Replacement
Neye ihtiyacın var
  1. Nintendo GameCube Front and Back Panel Replacement, Top Case: adım 1, 3 resimden 1. Nintendo GameCube Front and Back Panel Replacement, Top Case: adım 1, 3 resimden 2. Nintendo GameCube Front and Back Panel Replacement, Top Case: adım 1, 3 resimden 3.
    • Turn over the Gamecube so that the bottom side is facing up.
    • Use the 4.5 mm Gamebit screwdriver to remove all four screws.
  2. Nintendo GameCube Front and Back Panel Replacement: adım 2, 3 resimden 1. Nintendo GameCube Front and Back Panel Replacement: adım 2, 3 resimden 2. Nintendo GameCube Front and Back Panel Replacement: adım 2, 3 resimden 3.
    • With the bottom side of the GameCube facing upward and the screws removed, carefully pull the outer shell of the unit away from the top half.
    • Move the GameCube so that the inside is facing upwards.
  3. Nintendo GameCube Front and Back Panel Replacement, Removing the back panel: adım 3, 1 resimden 1.
    • Gently press down on the clips located on either side of the back panel.
    • Carefully remove the back panel from the GameCube.
  4. Nintendo GameCube Front and Back Panel Replacement: adım 4, 1 resimden 1.
    • Unclip the controller ports at the front of the unit.
    • A ribbon cable (outlined in orange) is still attached to the unit. Do not disconnect this cable.
    • Controller ports are where the controllers plug into the game console, and are a half circular shape.
  5. Nintendo GameCube Front and Back Panel Replacement, Separate the casing: adım 5, 2 resimden 1. Nintendo GameCube Front and Back Panel Replacement, Separate the casing: adım 5, 2 resimden 2.
    • This step may not be necessary depending on your end goal
    • Use a Phillips #2 screwdriver to remove the two screws on the back of the control port.
    • Carefully separate the gray outer casing of the control port and the circuit board.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
dcarlin
390 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-2, Maness Fall 2009 Cal Poly, Team 6-2, Maness Fall 2009 üyesi
CPSU-MANESS-F09S6G2
4 Üyeler
45 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 41
Son 30 gün: 167
Her zaman: 17,754
