Ana içeriğe geç
Nintendo GameCube Motherboard Replacement
Neye ihtiyacın var
  1. Nintendo GameCube Motherboard Replacement, Top Case: adım 1, 3 resimden 1. Nintendo GameCube Motherboard Replacement, Top Case: adım 1, 3 resimden 2. Nintendo GameCube Motherboard Replacement, Top Case: adım 1, 3 resimden 3.
    • Turn over the Gamecube so that the bottom side is facing up.
    • Use the 4.5 mm Gamebit screwdriver to remove all four screws.
    FixBot'a Sor
    Yorum Ekle
  2. Nintendo GameCube Motherboard Replacement: adım 2, 3 resimden 1. Nintendo GameCube Motherboard Replacement: adım 2, 3 resimden 2. Nintendo GameCube Motherboard Replacement: adım 2, 3 resimden 3.
    • With the bottom side of the GameCube facing upward and the screws removed, carefully pull the outer shell of the unit away from the top half.
    • Move the GameCube so that the inside is facing upwards.
    FixBot'a Sor
    Yorum Ekle
  3. Nintendo GameCube Motherboard Replacement, Removing the back panel: adım 3, 1 resimden 1.
    • Gently press down on the clips located on either side of the back panel.
    • Carefully remove the back panel from the GameCube.
    FixBot'a Sor
    Yorum Ekle
  4. Nintendo GameCube Motherboard Replacement: adım 4, 1 resimden 1.
    • Unclip the controller ports at the front of the unit.
    • A ribbon cable (outlined in orange) is still attached to the unit. Do not disconnect this cable.
    • Controller ports are where the controllers plug into the game console, and are a half circular shape.
    FixBot'a Sor
    Yorum Ekle
  5. Nintendo GameCube Motherboard Replacement, Separate the casing: adım 5, 2 resimden 1. Nintendo GameCube Motherboard Replacement, Separate the casing: adım 5, 2 resimden 2.
    • This step may not be necessary depending on your end goal
    • Use a Phillips #2 screwdriver to remove the two screws on the back of the control port.
    • Carefully separate the gray outer casing of the control port and the circuit board.
    FixBot'a Sor
    Yorum Ekle
  6. Nintendo GameCube Motherboard Replacement, Remove Nintendo GameCube Optical Drive Assembly: adım 6, 2 resimden 1. Nintendo GameCube Motherboard Replacement, Remove Nintendo GameCube Optical Drive Assembly: adım 6, 2 resimden 2.
    • The left side of the unit contains the cooling fan and its housing.
    • Carefully remove the two screws attaching the cooling fan housing to the unit.
    • Do not detach the red and black cooling fan wire from the main unit. Boxed in orange.
    FixBot'a Sor
    Yorum Ekle
  7. Nintendo GameCube Motherboard Replacement: adım 7, 2 resimden 1. Nintendo GameCube Motherboard Replacement: adım 7, 2 resimden 2.
    • Remove the four Phillips #1 screws retaining the ground springs.
    • Carefully remove the ground springs from the main unit.
    FixBot'a Sor
    Yorum Ekle
  8. Nintendo GameCube Motherboard Replacement: adım 8, 2 resimden 1. Nintendo GameCube Motherboard Replacement: adım 8, 2 resimden 2.
    • The optical drive is secured to a metal plate.
    • Using a Phillips #2 screwdriver, unscrew the twelve screws that are around the outer edge of the optical drive.
    FixBot'a Sor
    Yorum Ekle
  9. Nintendo GameCube Motherboard Replacement, Remove the assembly: adım 9, 3 resimden 1. Nintendo GameCube Motherboard Replacement, Remove the assembly: adım 9, 3 resimden 2. Nintendo GameCube Motherboard Replacement, Remove the assembly: adım 9, 3 resimden 3.
    • Carefully separate the optical drive assembly from the rest of the GameCube unit.
    • The optical drive assembly is secured to the motherboard underneath by a slot; some force may be required to carefully free the assembly.
    • The metal plate and the actual optical drive will remain attached.
    FixBot'a Sor
    Yorum Ekle
  10. Nintendo GameCube Motherboard Replacement, Motherboard: adım 10, 2 resimden 1. Nintendo GameCube Motherboard Replacement, Motherboard: adım 10, 2 resimden 2.
    • With the Optical Drive Assembly removed, your GameCube should now look like this.
    • Remove the 6 screws (circled in orange) on the heat sink using a #1 Phillips screwdriver.
    FixBot'a Sor
    Yorum Ekle
  11. Nintendo GameCube Motherboard Replacement: adım 11, 2 resimden 1. Nintendo GameCube Motherboard Replacement: adım 11, 2 resimden 2.
    • Gently lift the motherboard from base (as shown in second picture).
    FixBot'a Sor
    Yorum Ekle
  12. Nintendo GameCube Motherboard Replacement: adım 12, 2 resimden 1. Nintendo GameCube Motherboard Replacement: adım 12, 2 resimden 2.
    • Carefully disconnect the ribbon cable connecting the motherboard with the front panel.
    • At this point you can replace the old motherboard with a new one and enjoy your now-functional GameCube!
    FixBot'a Sor
    Yorum Ekle
Sonuç
16 farklı kişi bu kılavuzu tamamladı.
mwbisson
1.161 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-2, Maness Fall 2009 Cal Poly, Team 6-2, Maness Fall 2009 üyesi
CPSU-MANESS-F09S6G2
4 Üyeler
45 adet Kılavuz yazıldı
3Kılavuz Yorumları
What happens if you disconnect that cable (localizated on Step 4)?
Santi12008 - Yanıt Paylaş
Its soldered to the front-board and the connector is on the main-board under the disc assembly, trying to remove it will break it.
Joseph Lalone - Yanıt Paylaş
I have been having trouble with my cube shorting out when I insert a memory card into slot A. What is the best way to get at it see if this is the case, and what should I be looking for?
Many thanks
farrell dann - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 11
Son 7 gün: 59
Son 30 gün: 287
Her zaman: 36,840
