Ana içeriğe geç
Nintendo Gameboy Pocket Shell-Side Battery Terminal Corrosion Removal
Neye ihtiyacın var
  1. Nintendo Gameboy Pocket Shell-Side Battery Terminal Corrosion Removal, Nintendo Gameboy Pocket Shell-Side Battery Terminal Corrosion Removal: adım 1, 1 resimden 1.
    • Remove the battery cover and batteries.
  2. Nintendo Gameboy Pocket Shell-Side Battery Terminal Corrosion Removal: adım 2, 1 resimden 1.
    • Remove the six 8mm screws using a Y1 Tri-point screwdriver.
    • Place your screws in a small container to keep them safe.
  3. Nintendo Gameboy Pocket Shell-Side Battery Terminal Corrosion Removal: adım 3, 1 resimden 1.
    • Separate the front and back side of the Gameboy by gently pulling them apart.
  4. Nintendo Gameboy Pocket Shell-Side Battery Terminal Corrosion Removal: adım 4, 1 resimden 1.
    • Using a flathead screwdriver (or flat piece of plastic), nudge in the clip holding the shell-side battery terminal in place to release it from the shell.
  5. Nintendo Gameboy Pocket Shell-Side Battery Terminal Corrosion Removal: adım 5, 2 resimden 1. Nintendo Gameboy Pocket Shell-Side Battery Terminal Corrosion Removal: adım 5, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Using a pair of tweezers, remove the battery terminal from the shell.
  6. Nintendo Gameboy Pocket Shell-Side Battery Terminal Corrosion Removal: adım 6, 2 resimden 1. Nintendo Gameboy Pocket Shell-Side Battery Terminal Corrosion Removal: adım 6, 2 resimden 2.
    • Add isopropyl alcohol to a toothbrush.
    • Spread a paper towel down to keep your workspace clean.
    • Scrub the terminal where the corrosion is to remove as much as possible. If most of the corrosion is removed, skip to step 10.
  7. Nintendo Gameboy Pocket Shell-Side Battery Terminal Corrosion Removal: adım 7, 1 resimden 1.
    • Use the steel wool to remove as much corrosion as possible.
  8. Nintendo Gameboy Pocket Shell-Side Battery Terminal Corrosion Removal: adım 8, 2 resimden 1. Nintendo Gameboy Pocket Shell-Side Battery Terminal Corrosion Removal: adım 8, 2 resimden 2.
    • Add metal polish to a paper towel.
    • Polish the battery terminal to remove the remainder of the corrosion.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Sarah Travers
319 İtibar
1 Kılavuz yazıldı
Ekip
4Kılavuz Yorumları
Thank you for the guide! Resurrected a Gameboy Pocket today that has graphical glitches on the boot screen and sometimes crashed mid-game when a cartridge could load. This process seems to have completely remediated that.
I only needed to complete through step 6 to get clean shiny contacts in my case.
sacratoy - Yanıt
Much better than the usual battery replacement guides! Most of those are practically useless as they do little more than say, “replace the batteries,” which is pretty much self-evident, and noting, “clean any corrosion,” without explaining how to do that!
Wolf Naegeli - Yanıt
Is there a corresponding guide for cleaning the sections of the battery terminal which are fixed to the board, i.e. not shell-side?
Samuel Bradley - Yanıt
This worked for me (without the need for steel wool/polish). Thank you!
Ray F - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 32
Son 30 gün: 132
Her zaman: 8,679
