Ana içeriğe geç
Nintendo NES Advantage B Button Replacement
Neye ihtiyacın var
  1. Nintendo NES Advantage B Button Replacement, Back Panel: adım 1, 1 resimden 1.
    • Remove the four sticky pads from the bottom of the device.
    • If the pads are stuck, use a spudger to remove them.
    FixBot'a Sor
    Yorum Ekle
  2. Nintendo NES Advantage B Button Replacement: adım 2, 2 resimden 1. Nintendo NES Advantage B Button Replacement: adım 2, 2 resimden 2.
    • Remove the six 8 mm screws from the bottom of the device with a Phillips #0 screwdriver.
    • Use your hands to pull the back panel away from the controller.
    FixBot'a Sor
    Yorum Ekle
  3. Nintendo NES Advantage B Button Replacement, Circuit Board: adım 3, 2 resimden 1. Nintendo NES Advantage B Button Replacement, Circuit Board: adım 3, 2 resimden 2.
    • Remove the three 14 mm screws from the gray cross with a Phillips #0 screwdriver.
    • Lift the gray component away from the device.
    FixBot'a Sor
    Yorum Ekle
  4. Nintendo NES Advantage B Button Replacement: adım 4, 1 resimden 1.
    • Lift up the black wire and move it to the side.
    FixBot'a Sor
    Yorum Ekle
  5. Nintendo NES Advantage B Button Replacement: adım 5, 3 resimden 1. Nintendo NES Advantage B Button Replacement: adım 5, 3 resimden 2. Nintendo NES Advantage B Button Replacement: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Remove the two silver knobs on the front of the device.
    • Unscrew the two silver nuts using a flathead screwdriver.
    • Remove each silver nut and silver washer using a pair of tweezers.
    FixBot'a Sor
    Yorum Ekle
  6. Nintendo NES Advantage B Button Replacement: adım 6, 2 resimden 1. Nintendo NES Advantage B Button Replacement: adım 6, 2 resimden 2.
    • Remove the remaining three 8 mm screws on the circuit board with a Phillips #0 screwdriver.
    • Remove the silver bracket from the top of the circuit board.
    FixBot'a Sor
    Yorum Ekle
  7. Nintendo NES Advantage B Button Replacement: adım 7, 1 resimden 1.
    • Remove the circuit board from the controller.
    FixBot'a Sor
    Yorum Ekle
  8. Nintendo NES Advantage B Button Replacement, B Button: adım 8, 1 resimden 1.
    • Remove the B button from the case (or the circuit board if it got stuck).
    FixBot'a Sor
    Yorum Ekle
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 35
Her zaman: 461
