Ana içeriğe geç
Nintendo Switch Dock Circuit Board Replacement
Neye ihtiyacın var
  1. Nintendo Switch Dock Circuit Board Replacement, Remove cables and wires: adım 1, 1 resimden 1.
    • Unclip the back plate. It will fold back to expose the power wire and the HDMI cable.
    FixBot'a Sor
    Yorum Ekle
  2. Nintendo Switch Dock Circuit Board Replacement, Prepare dock for disassembly: adım 2, 1 resimden 1.
    • Remove the Switch from the dock
    • Orient the dock so that the adapter block faces up like shown
    FixBot'a Sor
    Yorum Ekle
  3. Nintendo Switch Dock Circuit Board Replacement, Removing first set of screws: adım 3, 3 resimden 1. Nintendo Switch Dock Circuit Board Replacement, Removing first set of screws: adım 3, 3 resimden 2. Nintendo Switch Dock Circuit Board Replacement, Removing first set of screws: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Using a Tri-head 360x50 (or Y00) driver, unscrew the four screws shown (1, 2, 3, 4) and use mini-tweezers to remove the screws. These are short.
    • Place the screws in a secure location where you will remember to get them later.
    • If you have an OLED dock, the bottom left screw is hidden under a plastic cover (2nd photo, red). To remove this cover, there's a screw on the bottom (underside) of the dock itself (2nd photo, orange). Remove that first, then you can remove the cover with a pry tool or fingernail, and then you can remove the last Y-screw (3rd photo, orange).
    FixBot'a Sor
    Yorum Ekle
  4. Nintendo Switch Dock Circuit Board Replacement: adım 4, 1 resimden 1.
    • Using Tri-head 360x50 (or Y00) driver, unscrew the next four screws shown (A, B, C, D) and use the mini-tweezers to remove the screws. These screws will be longer.
    • Place the screws in a secure location.
    FixBot'a Sor
    Yorum Ekle
  5. Nintendo Switch Dock Circuit Board Replacement, Removing the backing: adım 5, 2 resimden 1. Nintendo Switch Dock Circuit Board Replacement, Removing the backing: adım 5, 2 resimden 2.
    • Carefully pull to remove the backing from the switch dock, exposing the circuit board.
    FixBot'a Sor
    Yorum Ekle
  6. Nintendo Switch Dock Circuit Board Replacement, Remove the circuit board: adım 6, 1 resimden 1.
    • Carefully unplug the red and black cable connecting the circuit board with the dock housing
    • This cable can be more easily removed with a pair of needle-nosed pliers. Clamp on to the plastic casing and gently pull to remove the cable
    FixBot'a Sor
    Yorum Ekle
  7. Nintendo Switch Dock Circuit Board Replacement, Remove the film cable: adım 7, 3 resimden 1. Nintendo Switch Dock Circuit Board Replacement, Remove the film cable: adım 7, 3 resimden 2. Nintendo Switch Dock Circuit Board Replacement, Remove the film cable: adım 7, 3 resimden 3.
    • Gently pull the film cable out of the circuit board. The cable should slide free when lightly pulled. Don't pull on it, you're liable to break the cable or connector.
    • Instead, look at the connector itself. There's a flap (second photo) on the top side of the connector. Using a spudger or fingernail (NO METAL - if you tear the cable, nothing will work and you'll be very sad) to pop up that flap. It's a locking mechanism, so there's a bit of resistance.
    • Once you've lifted the flap up, take a note of the orientation of the cable and how it sits in the connector. The cable has two tabs, on one the right and one on the left (marked with a red circle), which align the cable in the connector. Good idea to take a photo at this step for reference later.
    • The cable can then be gently lifted (to get the tabs out of their alignment grooves) and pulled back away from the connector to release it. Close the locking latch so it doesn't break off later.
    FixBot'a Sor
    Yorum Ekle
    • Unpack and inspect replacement circuit board - check for any damage or faults
    FixBot'a Sor
    Yorum Ekle
  8. Nintendo Switch Dock Circuit Board Replacement, Reconnect film cable: adım 9, 2 resimden 1. Nintendo Switch Dock Circuit Board Replacement, Reconnect film cable: adım 9, 2 resimden 2.
    • Carefully reconnect the film cable to the replacement circuit board. The cable should slide in when gentle pressure is applied. Lift the locking flap (see step 7 for images) with a plastic (NO METAL) tool or your fingernail, slide the cable in and make sure the tabs are seated properly before closing the locking latch.
    • Ensure the cable is oriented correctly before insertion to avoid damage.
    FixBot'a Sor
    Yorum Ekle
  9. Nintendo Switch Dock Circuit Board Replacement, Reconnect red/black cable: adım 10, 2 resimden 1. Nintendo Switch Dock Circuit Board Replacement, Reconnect red/black cable: adım 10, 2 resimden 2.
    • Make sure the cable is oriented correctly - you can check the port to make sure the holes will line up correctly
    • Align plug - end of cable to port and apply gentle pressure. The cable should slide back into place.
    • The circuit board should fit without obstruction.
    FixBot'a Sor
    Yorum Ekle
  10. Nintendo Switch Dock Circuit Board Replacement, Reinsert circuit board: adım 11, 1 resimden 1.
    • Gently apply pressure to the circuit board to ensure it seats into the housing.
    FixBot'a Sor
    Yorum Ekle
  11. Nintendo Switch Dock Circuit Board Replacement, Put backing on: adım 12, 1 resimden 1.
    • Place backing onto dock. All screw holes should line up.
    • Apply gentle pressure. (You should feel a slight "give" as it seats properly)
    FixBot'a Sor
    Yorum Ekle
  12. Nintendo Switch Dock Circuit Board Replacement, Reinsert screws Part 1: adım 13, 1 resimden 1.
    • Use Tri-Head driver to reinsert screws (A, B, C, D).
    • These are the longer (6 or 6.5mm) ones.
    FixBot'a Sor
    Yorum Ekle
  13. Nintendo Switch Dock Circuit Board Replacement, Reinsert screws Part 2: adım 14, 1 resimden 1.
    • Use Tri-head driver to reinsert screws (1, 2, 3, 4).
    • These are the shorter (3mm) ones.
    FixBot'a Sor
    Yorum Ekle
  14. Nintendo Switch Dock Circuit Board Replacement, Reinsert cables: adım 15, 1 resimden 1.
    • Plug HDMI and power cable into switch dock.
    FixBot'a Sor
    Yorum Ekle
  15. Nintendo Switch Dock Circuit Board Replacement, Connect with an HDMI device: adım 16, 1 resimden 1.
    • Plug HDMI cable into a device with an HDMI port (TV, monitor, computer, etc.) (NOTE: need adapter for PC for video and audio connection)
    FixBot'a Sor
    Yorum Ekle
  16. Nintendo Switch Dock Circuit Board Replacement, Using the dock Part 1: adım 17, 1 resimden 1.
    • Insert Nintendo Switch into dock and turn it on.
    • The dock should charge your switch. If it doesn't, check the power supply/power cable
    • When correctly seated in the dock, the Switch screen will remain black
    FixBot'a Sor
    Yorum Ekle
    • Use Switch normally to test audio and video output
    • If Switch works normally but the dock doesn't, check to make sure the following are true:
    • Both cables are plugged in correctly
    • Both cables are not obstructed or damaged
    • Circuit board is not damaged
    • Circuit board seats correctly into housing
    FixBot'a Sor
    Yorum Ekle
Sonuç
All electrical equipment should be stored safely out of the way of hazards. After replacement, the Switch Dock should function properly.
14 farklı kişi bu kılavuzu tamamladı.
[deleted]
651 İtibar
1 Kılavuz yazıldı
6Kılavuz Yorumları
At https://www.hollywood-docks.com, we specialize in new dock installations, existing dock repairs and updates, seawall installations and repairs, deck and patio construction, and much more. We pride ourselves on providing high-quality craftsmanship and exceptional customer service.
Paul Walker - Yanıt Paylaş
Wrong kind of dock, bro.
modtang - Yanıt Paylaş
Conecta el cable HDMI a un dispositivo con un puerto HDMI
Vlad Luk - Yanıt Paylaş
Enchufa el HDMI y el cable de alimentación en la base de la Switch.
had a bad surge and now dock isn't working (but the power cord will charge the switch directly)
how do I tell if it is the circuit board or the USBC board that is bad?
Jeff - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 31
Son 7 gün: 220
Son 30 gün: 982
Her zaman: 49,322
