Giriş
Follow this guide to replace a broken or faulty circuit board in your Nintendo Switch dock.
Required Tools: Tri-head 360x50 or Y00 driver, mini-tweezers, needle-nose pliers
Neye ihtiyacın var
Unclip the back plate. It will fold back to expose the power wire and the HDMI cable.
Remove the Switch from the dock
Orient the dock so that the adapter block faces up like shown
Bu adımda kullanılan alet:Tweezers$4.99
Using a Tri-head 360x50 (or Y00) driver, unscrew the four screws shown (1, 2, 3, 4) and use mini-tweezers to remove the screws. These are short.
Place the screws in a secure location where you will remember to get them later.
Carefully pull to remove the backing from the switch dock, exposing the circuit board.
Carefully unplug the red and black cable connecting the circuit board with the dock housing
This cable can be more easily removed with a pair of needle-nosed pliers. Clamp on to the plastic casing and gently pull to remove the cable
Gently pull the film cable out of the circuit board. The cable should slide free when lightly pulled.Don't pull on it, you're liable to break the cable or connector. -
Instead, look at the connector itself. There's a flap (second photo) on the top side of the connector. Using a spudger or fingernail (NO METAL - if you tear the cable, nothing will work and you'll be very sad) to pop up that flap. It's a locking mechanism, so there's a bit of resistance.
Once you've lifted the flap up, take a note of the orientation of the cable and how it sits in the connector. The cable has two tabs, on one the right and one on the left (marked with a red circle), which align the cable in the connector. Good idea to take a photo at this step for reference later.
The cable can then be gently lifted (to get the tabs out of their alignment grooves) and pulled back away from the connector to release it. Close the locking latch so it doesn't break off later.
Unpack and inspect replacement circuit board - check for any damage or faults
Carefully reconnect the film cable to the replacement circuit board.
The cable should slide in when gentle pressure is applied.Lift the locking flap (see step 7 for images) with a plastic (NO METAL) tool or your fingernail, slide the cable in and make sure the tabs are seated properly before closing the locking latch. -
Ensure the cable is oriented correctly before insertion to avoid damage.
Make sure the cable is oriented correctly - you can check the port to make sure the holes will line up correctly
Align plug - end of cable to port and apply gentle pressure. The cable should slide back into place.
The circuit board should fit without obstruction.
Gently apply pressure to the circuit board to ensure it seats into the housing.
Place backing onto dock. All screw holes should line up.
Apply gentle pressure. (You should feel a slight "give" as it seats properly)
Plug HDMI cable into a device with an HDMI port (TV, monitor, computer, etc.) (NOTE: need adapter for PC for video and audio connection)
Insert Nintendo Switch into dock and turn it on.
The dock should charge your switch. If it doesn't, check the power supply/power cable
When correctly seated in the dock, the Switch screen will remain black
Use Switch normally to test audio and video output
If Switch works normally but the dock doesn't, check to make sure the following are true:
Both cables are plugged in correctly
Both cables are not obstructed or damaged
Circuit board is not damaged
Circuit board seats correctly into housing
All electrical equipment should be stored safely out of the way of hazards. After replacement, the Switch Dock should function properly.
13 farklı kişi bu kılavuzu tamamladı.
6Kılavuz Yorumları
At https://www.hollywood-docks.com, we specialize in new dock installations, existing dock repairs and updates, seawall installations and repairs, deck and patio construction, and much more. We pride ourselves on providing high-quality craftsmanship and exceptional customer service.
Wrong kind of dock, bro.
modtang -
