Giriş
Over time, Switch models may malfunction. One part that may stop functioning correctly is the SD card reader. The Switch system is notorious for its small internal storage space, so it might be impossible for owners to download additional game titles without an SD card.
A broken SD card reader or connector socket can prevent the user from properly using an SD card altogether. For this project, experience with applying flux is strongly recommended. Additionally, you should have prior knowledge of how to use a heat gun.
Power off the Switch.
Press and hold the black buttons on the back of the joy-cons, and slide them off.
Remove the 4 tri-wing Y0 screws from the back of the device.
Lift the SD card cover and remove the Phillips #00 screw from the back of the device.
Carefully remove the back cover from the device.
Remove the sponge from the SD card reader
Slowly remove the SD card reader using tweezers.
Remove the 6 Phillips head #00 screws from the metal plate inside of the device.
Lift and remove the metal plate from the device.
Apply a new coat of flux.
Smoothen the surface area using a cotton swab.
Insert the new connector socket into the flux.
2 farklı kişi bu kılavuzu tamamladı.
