Ana içeriğe geç
Giriş
Follow this guide to replace a faulty or damaged screen on the Nintendo Switch Lite.
The Switch Lite uses JIS screws, but you can use a Phillips screwdriver in a pinch. Be very careful not to strip the screws. iFixit's Phillips bits are designed to be cross-compatible with JIS-style screws.
Note: Removing the joysticks and buttons isn’t required, but it makes this repair much easier.
Note: If the display glass is cracked or shattered, but the screen still works, you’ll need to replace the digitizer instead.
Note: This procedure requires removing the shield plate and heat sink. The thermal paste will need to be cleaned off of both components—as well as the CPU—and reapplied before reinstalling the shield plate and heat sink.
    • Before beginning this repair, make sure that the device is completely turned off.
    • Use a Y00 screwdriver to remove the four 6.3 mm-long screws securing the back panel.
  1. Nintendo Switch Lite Screen Replacement, Remove the top and bottom back panel screws: adım 2, 2 resimden 1. Nintendo Switch Lite Screen Replacement, Remove the top and bottom back panel screws: adım 2, 2 resimden 2.
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the following screws securing the back panel:
    • Two 3.6 mm-long screws on the top of the device
    • Two 3.6 mm-long screws on the bottom of the device
    • To prevent these tight screws from stripping, apply firm downward force, work slowly and try a different screwdriver if the screws won't come out.
  2. Nintendo Switch Lite Screen Replacement, Release the clips securing the back panel: adım 3, 2 resimden 1. Nintendo Switch Lite Screen Replacement, Release the clips securing the back panel: adım 3, 2 resimden 2.
    • Insert an opening tool into the left speaker grille on the bottom of the device.
    • Twist the opening tool to release the clips securing the back panel.
    • Avoid inserting the opening tool further than required to prevent damage to the speaker module.
  3. Nintendo Switch Lite Screen Replacement, Continue releasing the clips around the device: adım 4, 2 resimden 1. Nintendo Switch Lite Screen Replacement, Continue releasing the clips around the device: adım 4, 2 resimden 2.
    • Slide the opening tool around the bottom-left corner to release the clips on the left side of the device.
  4. Nintendo Switch Lite Screen Replacement, Twist to release the clips: adım 5, 2 resimden 1. Nintendo Switch Lite Screen Replacement, Twist to release the clips: adım 5, 2 resimden 2.
    • Insert an opening tool into the right speaker grille on the bottom of the device.
    • Twist the opening tool to release the clips.
  5. Nintendo Switch Lite Screen Replacement, Slide and pry around the corners: adım 6, 2 resimden 1. Nintendo Switch Lite Screen Replacement, Slide and pry around the corners: adım 6, 2 resimden 2.
    • Slide and pry the opening tool around the bottom-right corner to release the clips on the right side of the device.
  6. Nintendo Switch Lite Screen Replacement: adım 7, 2 resimden 1. Nintendo Switch Lite Screen Replacement: adım 7, 2 resimden 2.
    • Continue sliding and prying the opening tool along the gap on the top of the device to release the clips.
  7. Nintendo Switch Lite Screen Replacement, Remove the back panel: adım 8, 3 resimden 1. Nintendo Switch Lite Screen Replacement, Remove the back panel: adım 8, 3 resimden 2. Nintendo Switch Lite Screen Replacement, Remove the back panel: adım 8, 3 resimden 3.
    • Lift the bottom edge of the back panel, opening it like a book.
    • Remove the back panel.
  8. Nintendo Switch Lite Screen Replacement, Remove the shield plate: adım 9, 1 resimden 1.
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the following four screws:
    • Three 3.1 mm screws
    • One 4.5 mm screw
  9. Nintendo Switch Lite Screen Replacement: adım 10, 3 resimden 1. Nintendo Switch Lite Screen Replacement: adım 10, 3 resimden 2. Nintendo Switch Lite Screen Replacement: adım 10, 3 resimden 3.
    • Use a spudger or your fingers to lift the shield plate up and out of the device.
    • You may feel a bit of resistance. This is normal, since the shield plate is slightly bonded to the heat sink with thermal paste.
    • Remove the shield plate.
    • Clean off the old thermal paste from the shield plate and heat sink using isopropyl alcohol and a microfiber cloth. Apply new thermal paste to the heat sink before reassembly.
  10. Nintendo Switch Lite Screen Replacement, Disconnect the battery: adım 11, 2 resimden 1. Nintendo Switch Lite Screen Replacement, Disconnect the battery: adım 11, 2 resimden 2.
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the motherboard interconnect cable's ZIF connector.
  11. Nintendo Switch Lite Screen Replacement: adım 12, 2 resimden 1. Nintendo Switch Lite Screen Replacement: adım 12, 2 resimden 2.
    • Use a pair of tweezers to slide the interconnect cable out of its connector on the motherboard.
  12. Nintendo Switch Lite Screen Replacement: adım 13, 2 resimden 1. Nintendo Switch Lite Screen Replacement: adım 13, 2 resimden 2.
    • Use the point of a spudger to pry the battery connector straight up and out of its socket on the motherboard.
  13. Nintendo Switch Lite Screen Replacement, Remove the heat sink: adım 14, 1 resimden 1.
    • Use the flat end of a spudger or your fingers to carefully peel up the foam that's lightly adhered to the fan.
    • The foam only needs to be peeled back enough to clear the fan.
  14. Nintendo Switch Lite Screen Replacement: adım 15, 1 resimden 1.
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the three 3 mm screws securing the heat sink to the motherboard.
  15. Nintendo Switch Lite Screen Replacement: adım 16, 3 resimden 1. Nintendo Switch Lite Screen Replacement: adım 16, 3 resimden 2. Nintendo Switch Lite Screen Replacement: adım 16, 3 resimden 3.
    • Use a spudger or your fingers to lift the heatsink up and off of the motherboard to remove it.
    • You may feel a bit of resistance. This is normal, since the heat sink is slightly bonded to the CPU with thermal paste.
    • Clean off the old thermal paste from the heat sink and CPU using isopropyl alcohol and a microfiber cloth. Apply new thermal paste to the CPU before reassembly.
  16. Nintendo Switch Lite Screen Replacement, Remove the game card reader and headphone jack: adım 17, 2 resimden 1. Nintendo Switch Lite Screen Replacement, Remove the game card reader and headphone jack: adım 17, 2 resimden 2.
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the game card reader cable's ZIF connector.
  17. Nintendo Switch Lite Screen Replacement: adım 18, 1 resimden 1.
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the seven 3.1 mm screws securing the game card reader and headphone jack.
  18. Nintendo Switch Lite Screen Replacement: adım 19, 3 resimden 1. Nintendo Switch Lite Screen Replacement: adım 19, 3 resimden 2. Nintendo Switch Lite Screen Replacement: adım 19, 3 resimden 3.
    • Use a pair of tweezers or your fingers to carefully lift the game card reader and maneuver it to the left to slide the cable out of its connector.
    • Remove the game card reader and headphone jack.
  19. Nintendo Switch Lite Screen Replacement, Remove the right trigger button assembly: adım 20, 1 resimden 1.
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the two 4.5 mm screws securing the right trigger button assembly to the motherboard.
  20. Nintendo Switch Lite Screen Replacement: adım 21, 2 resimden 1. Nintendo Switch Lite Screen Replacement: adım 21, 2 resimden 2.
    • Remove the right trigger button assembly.
  21. Nintendo Switch Lite Screen Replacement: adım 22, 2 resimden 1. Nintendo Switch Lite Screen Replacement: adım 22, 2 resimden 2.
    • Use a pair of tweezers or your fingers to remove the right trigger button assembly's rubber pad if it didn't stay attached to the button assembly.
  22. Nintendo Switch Lite Screen Replacement, Disconnect the antenna cables: adım 23, 3 resimden 1. Nintendo Switch Lite Screen Replacement, Disconnect the antenna cables: adım 23, 3 resimden 2. Nintendo Switch Lite Screen Replacement, Disconnect the antenna cables: adım 23, 3 resimden 3.
    • Use the point of a spudger to pry the black antenna cable straight up out of its socket on the motherboard.
    • Repeat the same process for the white antenna cable.
  23. Nintendo Switch Lite Screen Replacement, Disconnect the fan cable: adım 24, 1 resimden 1.
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the fan cable's ZIF connector.
  24. Nintendo Switch Lite Screen Replacement: adım 25, 2 resimden 1. Nintendo Switch Lite Screen Replacement: adım 25, 2 resimden 2.
    • Use a pair of tweezers to slide out the fan cable from its connector on the motherboard.
  25. Nintendo Switch Lite Screen Replacement, Disconnect the screen cable: adım 26, 2 resimden 1. Nintendo Switch Lite Screen Replacement, Disconnect the screen cable: adım 26, 2 resimden 2.
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the screen cable's ZIF connector.
  26. Nintendo Switch Lite Screen Replacement: adım 27, 2 resimden 1. Nintendo Switch Lite Screen Replacement: adım 27, 2 resimden 2.
    • Use a pair of tweezers to slide the screen cable out of its connector on the motherboard.
  27. Nintendo Switch Lite Screen Replacement, Disconnect the digitizer cable: adım 28, 2 resimden 1. Nintendo Switch Lite Screen Replacement, Disconnect the digitizer cable: adım 28, 2 resimden 2.
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the digitizer cable's ZIF connector.
  28. Nintendo Switch Lite Screen Replacement: adım 29, 2 resimden 1. Nintendo Switch Lite Screen Replacement: adım 29, 2 resimden 2.
    • Use a pair of tweezers to slide the digitizer cable out of its connector on the motherboard.
  29. Nintendo Switch Lite Screen Replacement, Disconnect the right joystick cable: adım 30, 2 resimden 1. Nintendo Switch Lite Screen Replacement, Disconnect the right joystick cable: adım 30, 2 resimden 2.
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the right joystick cable's ZIF connector.
  30. Nintendo Switch Lite Screen Replacement: adım 31, 2 resimden 1. Nintendo Switch Lite Screen Replacement: adım 31, 2 resimden 2.
    • Use a pair of tweezers to slide the right joystick cable out of its connector on the motherboard.
  31. Nintendo Switch Lite Screen Replacement, Remove the motherboard assembly: adım 32, 1 resimden 1.
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the following six screws securing the motherboard:
    • Three 4.5 mm screws
  32. Nintendo Switch Lite Screen Replacement: adım 33, 3 resimden 1. Nintendo Switch Lite Screen Replacement: adım 33, 3 resimden 2. Nintendo Switch Lite Screen Replacement: adım 33, 3 resimden 3.
    • Insert a spudger in the gap between the frame and the motherboard and lift the motherboard up and out of its recess.
    • Remove the motherboard assembly.
  33. Nintendo Switch Lite Screen Replacement, Remove the right joystick: adım 34, 1 resimden 1.
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the two 3.5 mm screws securing the joystick.
  34. Nintendo Switch Lite Screen Replacement: adım 35, 2 resimden 1. Nintendo Switch Lite Screen Replacement: adım 35, 2 resimden 2.
    • Use your fingers to remove the joystick.
    • There is a thin black gasket around the hole where the joystick pokes through the frame. Try not to disturb this gasket as you remove the joystick.
  35. Nintendo Switch Lite Screen Replacement, Remove the left speaker module: adım 36, 2 resimden 1. Nintendo Switch Lite Screen Replacement, Remove the left speaker module: adım 36, 2 resimden 2.
    • Use a pair of tweezers or your fingers to pull the left speaker cable straight up and out of its socket on the daughterboard.
    • Do not pull from the wires, or else you risk ripping the wires off the connector.
  36. Nintendo Switch Lite Screen Replacement: adım 37, 1 resimden 1.
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the 4.5 mm screw securing the left speaker module.
  37. Nintendo Switch Lite Screen Replacement: adım 38, 3 resimden 1. Nintendo Switch Lite Screen Replacement: adım 38, 3 resimden 2. Nintendo Switch Lite Screen Replacement: adım 38, 3 resimden 3.
    • Use your fingers to lift the speaker module up and out of its recess to remove it.
    • Part of the speaker module sits underneath a delicate ribbon cable. Take care not to snag the speaker module on the cable as you remove it.
  38. Nintendo Switch Lite Screen Replacement, Disconnect the motherboard interconnect cable: adım 39, 2 resimden 1. Nintendo Switch Lite Screen Replacement, Disconnect the motherboard interconnect cable: adım 39, 2 resimden 2.
  39. Nintendo Switch Lite Screen Replacement: adım 40, 2 resimden 1. Nintendo Switch Lite Screen Replacement: adım 40, 2 resimden 2.
    • Use a pair of tweezers to slide the motherboard interconnect cable out of its connector on the daughterboard.
  40. Nintendo Switch Lite Screen Replacement, Disconnect the screen and volume button cables: adım 41, 2 resimden 1. Nintendo Switch Lite Screen Replacement, Disconnect the screen and volume button cables: adım 41, 2 resimden 2.
    • Use an opening tool or your fingernail to flip up the small, hinged locking flaps on the two ribbon cable ZIF connectors.
  41. Nintendo Switch Lite Screen Replacement: adım 42, 3 resimden 1. Nintendo Switch Lite Screen Replacement: adım 42, 3 resimden 2. Nintendo Switch Lite Screen Replacement: adım 42, 3 resimden 3.
    • Use a pair of tweezers to slide the daughterboard screen cable out of its connector on the motherboard.
    • Repeat this procedure for the volume buttons cable.
  42. Nintendo Switch Lite Screen Replacement, Remove the volume buttons: adım 43, 2 resimden 1. Nintendo Switch Lite Screen Replacement, Remove the volume buttons: adım 43, 2 resimden 2.
    • Use a pair of tweezers or your fingers to remove the volume buttons.
  43. Nintendo Switch Lite Screen Replacement, Disconnect the joystick cable: adım 44, 2 resimden 1. Nintendo Switch Lite Screen Replacement, Disconnect the joystick cable: adım 44, 2 resimden 2.
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the left joystick cable's ZIF connector.
  44. Nintendo Switch Lite Screen Replacement: adım 45, 2 resimden 1. Nintendo Switch Lite Screen Replacement: adım 45, 2 resimden 2.
    • Use a pair of tweezers to slide the left joystick cable out of its connector on the daughterboard.
  45. Nintendo Switch Lite Screen Replacement, Remove the left trigger button assembly: adım 46, 1 resimden 1.
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the two 4.5 mm screws securing the left trigger button assembly.
  46. Nintendo Switch Lite Screen Replacement: adım 47, 2 resimden 1. Nintendo Switch Lite Screen Replacement: adım 47, 2 resimden 2.
    • Remove the left trigger button assembly.
  47. Nintendo Switch Lite Screen Replacement, Remove the daughterboard: adım 48, 1 resimden 1.
    • Two 4.5 mm screws
    • Two 6 mm screws
  48. Nintendo Switch Lite Screen Replacement: adım 49, 2 resimden 1. Nintendo Switch Lite Screen Replacement: adım 49, 2 resimden 2.
    • Use your fingers to lift the daughterboard up and out of its recess to remove it.
  49. Nintendo Switch Lite Screen Replacement, Remove the left joystick: adım 50, 1 resimden 1.
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the two 3.5 mm screws securing the left joystick.
  50. Nintendo Switch Lite Screen Replacement: adım 51, 3 resimden 1. Nintendo Switch Lite Screen Replacement: adım 51, 3 resimden 2. Nintendo Switch Lite Screen Replacement: adım 51, 3 resimden 3.
    • Use the flat end of a spudger to lift the joystick up and out of its recess.
  51. Nintendo Switch Lite Screen Replacement, Remove the midframe assembly: adım 52, 1 resimden 1.
    • Three 2.5 mm screws
    • One 6 mm screw
  52. Nintendo Switch Lite Screen Replacement: adım 53, 3 resimden 1. Nintendo Switch Lite Screen Replacement: adım 53, 3 resimden 2. Nintendo Switch Lite Screen Replacement: adım 53, 3 resimden 3.
    • Use a spudger or your fingers to lift the midframe assembly up and out of its recess.
    • Remove the midframe assembly.
  53. Nintendo Switch Lite Screen Replacement, Remove the buttons: adım 54, 2 resimden 1. Nintendo Switch Lite Screen Replacement, Remove the buttons: adım 54, 2 resimden 2.
    • At this point in the repair, remove all of the buttons if you haven't done so already, to prevent them from falling out and getting lost.
    • Use these two photos for reference.
  54. Nintendo Switch Lite Screen Replacement, Remove the screen: adım 55, 1 resimden 1.
    • Heat an iOpener and place it on the back side of the screen along the top edge for 1-2 minutes to help soften the adhesive.
    • A hair dryer or heat gun may also be used, but be careful not to overheat the screen if you plan on reusing it, as it's susceptible to heat damage.
  55. Nintendo Switch Lite Screen Replacement: adım 56, 2 resimden 1. Nintendo Switch Lite Screen Replacement: adım 56, 2 resimden 2.
    • Insert an opening pick between the frame and the top edge of the screen to begin separating the two components.
    • Make sure to insert the pick completely under the LCD panel so you don't split and damage it.
  56. Nintendo Switch Lite Screen Replacement: adım 57, 3 resimden 1. Nintendo Switch Lite Screen Replacement: adım 57, 3 resimden 2. Nintendo Switch Lite Screen Replacement: adım 57, 3 resimden 3.
    • Slide the opening pick along the top edge of the screen to slice the adhesive.
  57. Nintendo Switch Lite Screen Replacement: adım 58, 1 resimden 1.
    • Heat the back side of the screen along the right edge for 1-2 minutes to help soften the adhesive.
  58. Nintendo Switch Lite Screen Replacement: adım 59, 3 resimden 1. Nintendo Switch Lite Screen Replacement: adım 59, 3 resimden 2. Nintendo Switch Lite Screen Replacement: adım 59, 3 resimden 3.
    • Continue sliding the opening pick around the right edge of the screen, slicing the adhesive.
    • The screen and digitizer cables are placed in a way to prevent them from easily snagging on the opening pick, but still use caution when sliding the opening pick along the gap.
  59. Nintendo Switch Lite Screen Replacement: adım 60, 1 resimden 1.
    • Heat the back side of the screen along the bottom edge for 1-2 minutes to help soften the adhesive.
  60. Nintendo Switch Lite Screen Replacement: adım 61, 3 resimden 1. Nintendo Switch Lite Screen Replacement: adım 61, 3 resimden 2. Nintendo Switch Lite Screen Replacement: adım 61, 3 resimden 3.
    • Continue sliding the opening pick along the bottom edge of the screen to slice the adhesive.
    • You'll need to remove and reinsert the opening pick at various points along the screen's edge to work around the frame.
  61. Nintendo Switch Lite Screen Replacement: adım 62, 1 resimden 1.
    • Heat the back side of the screen along the left edge for 1-2 minutes to help soften the adhesive.
  62. Nintendo Switch Lite Screen Replacement: adım 63, 2 resimden 1. Nintendo Switch Lite Screen Replacement: adım 63, 2 resimden 2.
    • Continue sliding the opening pick along the left edge of the screen to slice the adhesive.
    • Take care not to snag the screen's daughterboard cable on the opening pick.
  63. Nintendo Switch Lite Screen Replacement: adım 64, 3 resimden 1. Nintendo Switch Lite Screen Replacement: adım 64, 3 resimden 2. Nintendo Switch Lite Screen Replacement: adım 64, 3 resimden 3.
    • Use the flat end of a spudger or your fingers to lift the screen up and out of the frame to remove it.
    • If you're reusing the screen (or your new screen does not come with pre-installed adhesive), follow this guide to install pre-cut adhesive around the perimeter before reassembly.
  64. Nintendo Switch Lite Screen Replacement: adım 65, 3 resimden 1. Nintendo Switch Lite Screen Replacement: adım 65, 3 resimden 2. Nintendo Switch Lite Screen Replacement: adım 65, 3 resimden 3.
    • If you're also replacing the digitizer, you can skip this step.
    • Use the flat end of a spudger to scrape off the remaining adhesive around the perimeter of the digitizer.
    • Prior to installing a new screen, use isopropyl alcohol and a microfiber cloth to clean and remove any residual adhesive from the back side of the digitizer. Wait several minutes for any remaining alcohol to evaporate before installing the screen.
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch Lite Answers community for help.
27 farklı kişi bu kılavuzu tamamladı.
Craig Lloyd
27.093 İtibar
82 adet Kılavuz yazıldı
11 Comments
Followed the guide to replaced a cracked screen on a Switch Lite, all good, guide was easy to follow and refitting wasn't too hard either, just a reversal of the disassembly
Luke Randall - Yanıt
Fantastic guide, exactly what I was looking for! Unfortunately I managed to make the tape unusable and I need tape to connect the lcd to the digitizer and the digitizer to the case. I will likely use 2-3mm tape for the lcd to digitizer but I'm unsure what to use to connect the digitizer to the case. Any suggestions?
Sam Red - Yanıt
Thanks for taking the time to type this up. Really appreciate the effort that went in to this guide.
Matthew D. H. - Yanıt
Great guide, I wish it would mention some of the procedures to tape the screen back in. After that, reversing the process was easy.
Stephen Hotchkiss - Yanıt
For gluing the screen and digitizer back in, I would strongly recommend liquid glue, like Zhanlida T-8000 for example. You can apply it very precisely and you can also correct/remove it if needed pretty easily. I used this stuff to repair around 200 phones and tablets in the last couple of years and were never disappointed.
Also I would remove the digitizer AND the screen together, before removing the screen first from the digitizer… This will make the process of removing the screen from the digitizer a lot easier and safer.
I have ordered a crystal replacement case and a used lite with a scratched digitizer.. Have glued in the replacement digitizer so far, the console should arrive tomorrow.
Gluing in the digitizer was a breeze, just applied some glue all around (be careful not to use too much) and then just pressed down the digitizer all around and put a book on the top… Let the glue harden for around 24 hours and you are good to go.
Will leave some feedback how the screen removal went tomorrow. ;)
mathiasludewig - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 89
Son 7 gün: 679
Son 30 gün: 2,929
Her zaman: 60,618
