Ana içeriğe geç
Nintendo Switch Lite Shield Plate Replacement
    • Before beginning this repair, make sure that the device is completely turned off.
    • Use a Y00 screwdriver to remove the four 6.3 mm-long screws securing the back panel.
  1. Nintendo Switch Lite Shield Plate Replacement, Remove the top and bottom back panel screws: adım 2, 2 resimden 1. Nintendo Switch Lite Shield Plate Replacement, Remove the top and bottom back panel screws: adım 2, 2 resimden 2.
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the following screws securing the back panel:
    • Two 3.6 mm-long screws on the top of the device
    • Two 3.6 mm-long screws on the bottom of the device
    • To prevent these tight screws from stripping, apply firm downward force, work slowly and try a different screwdriver if the screws won't come out.
  2. Nintendo Switch Lite Shield Plate Replacement, Release the clips securing the back panel: adım 3, 2 resimden 1. Nintendo Switch Lite Shield Plate Replacement, Release the clips securing the back panel: adım 3, 2 resimden 2.
    • Insert an opening tool into the left speaker grille on the bottom of the device.
    • Twist the opening tool to release the clips securing the back panel.
    • Avoid inserting the opening tool further than required to prevent damage to the speaker module.
  3. Nintendo Switch Lite Shield Plate Replacement, Continue releasing the clips around the device: adım 4, 2 resimden 1. Nintendo Switch Lite Shield Plate Replacement, Continue releasing the clips around the device: adım 4, 2 resimden 2.
    • Slide the opening tool around the bottom-left corner to release the clips on the left side of the device.
  4. Nintendo Switch Lite Shield Plate Replacement, Twist to release the clips: adım 5, 2 resimden 1. Nintendo Switch Lite Shield Plate Replacement, Twist to release the clips: adım 5, 2 resimden 2.
    • Insert an opening tool into the right speaker grille on the bottom of the device.
    • Twist the opening tool to release the clips.
  5. Nintendo Switch Lite Shield Plate Replacement, Slide and pry around the corners: adım 6, 2 resimden 1. Nintendo Switch Lite Shield Plate Replacement, Slide and pry around the corners: adım 6, 2 resimden 2.
    • Slide and pry the opening tool around the bottom-right corner to release the clips on the right side of the device.
  6. Nintendo Switch Lite Shield Plate Replacement: adım 7, 2 resimden 1. Nintendo Switch Lite Shield Plate Replacement: adım 7, 2 resimden 2.
    • Continue sliding and prying the opening tool along the gap on the top of the device to release the clips.
  7. Nintendo Switch Lite Shield Plate Replacement, Remove the back panel: adım 8, 3 resimden 1. Nintendo Switch Lite Shield Plate Replacement, Remove the back panel: adım 8, 3 resimden 2. Nintendo Switch Lite Shield Plate Replacement, Remove the back panel: adım 8, 3 resimden 3.
    • Lift the bottom edge of the back panel, opening it like a book.
    • Remove the back panel.
  8. Nintendo Switch Lite Shield Plate Replacement, Remove the shield plate: adım 9, 1 resimden 1.
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the following four screws:
    • Three 3.1 mm screws
    • One 4.5 mm screw
  9. Nintendo Switch Lite Shield Plate Replacement: adım 10, 3 resimden 1. Nintendo Switch Lite Shield Plate Replacement: adım 10, 3 resimden 2. Nintendo Switch Lite Shield Plate Replacement: adım 10, 3 resimden 3.
    • Use a spudger or your fingers to lift the shield plate up and out of the device.
    • You may feel a bit of resistance. This is normal, since the shield plate is slightly bonded to the heat sink with thermal paste.
    • Remove the shield plate.
    • Clean off the old thermal paste from the shield plate and heat sink using isopropyl alcohol and a microfiber cloth. Apply new thermal paste to the heat sink before reassembly.
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch Lite Answers community for help.
6 farklı kişi bu kılavuzu tamamladı.
Craig Lloyd
30.825 İtibar
82 adet Kılavuz yazıldı
0 Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 32
Son 30 gün: 158
Her zaman: 2,541
