Ana içeriğe geç
Giriş
Follow this guide to remove the left and right loudspeakers in a Nintendo Switch gaming console.
  1. Remove the four 6.3mm Tri-point Y00 screws from the rear panel.
    • Remove the four 6.3mm Tri-point Y00 screws from the rear panel.
  2. Remove the single 6.1mm JIS #000 screw from underneath the kickstand.
    • Remove the single 6.1mm JIS #000 screw from underneath the kickstand.
  3. Remove the two 2.7mm JIS #000 screws from the bottom of the device.
    • Remove the two 2.7mm JIS #000 screws from the bottom of the device.
  4. Remove the single 2.7mm JIS #000 screw from the top of the device.
    • Remove the single 2.7mm JIS #000 screw from the top of the device.
  5. Remove the single 3.8mm JIS #0 screw from the right Joy-Con rail. Remove the single 3.8mm JIS #0 screw from the left Joy-Con rail.
    • Remove the single 3.8mm JIS #0 screw from the right Joy-Con rail.
    • Remove the single 3.8mm JIS #0 screw from the left Joy-Con rail.
  6. Pull the rear panel up and off of the device. Pull the rear panel up and off of the device. Pull the rear panel up and off of the device.
    • Pull the rear panel up and off of the device.
  7. Remove the six 3.1mm JIS #000 screws from the shield plate.
    • Remove the six 3.1mm JIS #000 screws from the shield plate.
  8. Remove the shield plate from the device. A thick pink thermal compound bridges the gap between the shield plate and the copper heat sink underneath. Use our thermal paste guide to remove the old thermal compound and replace it with an appropriate, thick compound such as K5 Pro. A thick pink thermal compound bridges the gap between the shield plate and the copper heat sink underneath. Use our thermal paste guide to remove the old thermal compound and replace it with an appropriate, thick compound such as K5 Pro.
    • Remove the shield plate from the device.
    • A thick pink thermal compound bridges the gap between the shield plate and the copper heat sink underneath. Use our thermal paste guide to remove the old thermal compound and replace it with an appropriate, thick compound such as K5 Pro.
  9. Pull the right loudspeaker connector straight out of the socket on the motherboard. Pull the right loudspeaker connector straight out of the socket on the motherboard.
    • Pull the right loudspeaker connector straight out of the socket on the motherboard.
  10. Gently lift the loudspeaker up by its wires and pull out at a 45 degree angle to remove.
    • Gently lift the loudspeaker up by its wires and pull out at a 45 degree angle to remove.
  11. Pull the left loudspeaker connector straight out of the socket on the motherboard. Pull the left loudspeaker connector straight out of the socket on the motherboard.
    • Pull the left loudspeaker connector straight out of the socket on the motherboard.
  12. Gently lift the loudspeaker up by its wires and pull out at a 45 degree angle to remove.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Blake Klein
45.689 İtibar
48 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 10
Son 7 Gün: 39
Son 30 Gün: 134
Her zaman: 852
