Giriş
The front buttons on a Nintendo switch pro controller are supposed to be free flowing and have lightning fast response time. If your controller is not performing at the highest level it can then that means you will keep losing games. The controller has to be the best it can possibly be so that you can play up to your ultimate potential. If your front buttons are sticky, unresponsive, or will not press down all the way, use this guide to remove and replace your buttons. This guide requires a Phillips #00 screwdriver for screw removal.
Neye ihtiyacın var
Flip the controller over so the model stickers face the ceiling.
Use a JIS #00 screwdriver to remove the two black 8.4 mm screws that secure the handles, located at the ends of the handles.
Carefully remove the handle covers by pulling them away from the main body.
Use a JIS #00 screwdriver to remove the four silver 6.8 mm screws that secure the clear back plastic cover.
Carefully pry away the clear plastic cover using your fingernail.
Remove the lithium-ion battery by using a fingernail or plastic opening tool to pry it up on the left side.
Use a Phillips #1 screwdriver to remove the five 5 mm screws from the back of the controller.
The two case screws above the handgrips and the single case screw below the battery bay have a shallow seat. These three screws can be easily removed.
The two case screws adjacent to the ZR and ZL shoulder buttons have a deep seat. Use an extension or a Phillips screwdriver with a longer shaft to reach these screws.
Use the tip of an opening pick to open the black flap of the ZIF connector by pushing it upwards.
Bu adımda kullanılan alet:Tweezers$4.99
Use your fingers or a pair of blunt nose tweezers to disconnect the interconnect cable from its connector.
Remove the two 6.8 mm-long screws on the top circuit board using a Phillips screwdriver.
Use a spudger to flip up the locking tab on the ZIF connector.
Use a Phillips screwdriver to remove the 5 mm-long screw securing the front button board.
There may be an additional screw. If so, remove it now.
7 farklı kişi bu kılavuzu tamamladı.
4 Yorum
I broke the locking tab on the ZIF connector what can I do?
I’ve been looking myself and can’t find any replacement button board to buy - just asking again if anyone knows how to find or where to buy one?
if anyone else is reading this article... I easily found a nice set of replacement buttons that fit well on zedlabz. they're made in china and they are good quality rigid plastic with pleasant texturizing so they are easy to grip and press. happy fixing!
