Ana içeriğe geç
Nintendo Switch Pro Controller Joystick Caps Replacement
Neye ihtiyacın var
  1. Nintendo Switch Pro Controller Joystick Caps Replacement, Remove the screws: adım 1, 1 resimden 1.
    • Flip the controller over so the model stickers face the ceiling.
    • Use a JIS #00 screwdriver to remove the two black 8.4 mm screws that secure the handles, located at the ends of the handles.
    FixBot'a Sor
    Yorum Ekle
  2. Nintendo Switch Pro Controller Joystick Caps Replacement, Remove the handle covers: adım 2, 3 resimden 1. Nintendo Switch Pro Controller Joystick Caps Replacement, Remove the handle covers: adım 2, 3 resimden 2. Nintendo Switch Pro Controller Joystick Caps Replacement, Remove the handle covers: adım 2, 3 resimden 3.
    • Carefully remove the handle covers by pulling them away from the main body.
    FixBot'a Sor
    Yorum Ekle
  3. Nintendo Switch Pro Controller Joystick Caps Replacement, Remove the screws: adım 3, 1 resimden 1.
    • Use a JIS #00 screwdriver to remove the four silver 6.8 mm screws that secure the clear back plastic cover.
    FixBot'a Sor
    Yorum Ekle
  4. Nintendo Switch Pro Controller Joystick Caps Replacement, Unclip the plastic cover: adım 4, 3 resimden 1. Nintendo Switch Pro Controller Joystick Caps Replacement, Unclip the plastic cover: adım 4, 3 resimden 2. Nintendo Switch Pro Controller Joystick Caps Replacement, Unclip the plastic cover: adım 4, 3 resimden 3.
    • Carefully pry away the clear plastic cover using your fingernail.
    FixBot'a Sor
    Yorum Ekle
  5. Nintendo Switch Pro Controller Joystick Caps Replacement, Remove the clear plastic cover: adım 5, 1 resimden 1.
    • Remove the clear plastic cover.
    FixBot'a Sor
    Yorum Ekle
  6. Nintendo Switch Pro Controller Joystick Caps Replacement, Remove the battery: adım 6, 3 resimden 1. Nintendo Switch Pro Controller Joystick Caps Replacement, Remove the battery: adım 6, 3 resimden 2. Nintendo Switch Pro Controller Joystick Caps Replacement, Remove the battery: adım 6, 3 resimden 3.
    • Remove the lithium-ion battery by using a fingernail or plastic opening tool to pry it up on the left side.
    • Only a small amount of force is needed.
    FixBot'a Sor
    Yorum Ekle
  7. Nintendo Switch Pro Controller Joystick Caps Replacement, Remove the screws: adım 7, 3 resimden 1. Nintendo Switch Pro Controller Joystick Caps Replacement, Remove the screws: adım 7, 3 resimden 2. Nintendo Switch Pro Controller Joystick Caps Replacement, Remove the screws: adım 7, 3 resimden 3.
    • Use a Phillips #1 screwdriver to remove the five 5 mm screws from the back of the controller.
    • The two case screws above the handgrips and the single case screw below the battery bay have a shallow seat. These three screws can be easily removed.
    • The two case screws adjacent to the ZR and ZL shoulder buttons have a deep seat. Use an extension or a narrow PH1 Phillips screwdriver with a longer shaft to reach these screws.
    FixBot'a Sor
    Yorum Ekle
  8. Nintendo Switch Pro Controller Joystick Caps Replacement: adım 8, 3 resimden 1. Nintendo Switch Pro Controller Joystick Caps Replacement: adım 8, 3 resimden 2. Nintendo Switch Pro Controller Joystick Caps Replacement: adım 8, 3 resimden 3.
    • There's an adhesive pad located in the center of each handle. It will require a bit of force to pry away the front cover, but be mindful of the attached ribbon cable.
    • Delicately take off the plastic cover from the controller.
    • Don't completely remove the front cover just yet, as it's still attached to the motherboard via a white ribbon cable.
    FixBot'a Sor
    Yorum Ekle
  9. Nintendo Switch Pro Controller Joystick Caps Replacement, Open the flap: adım 9, 2 resimden 1. Nintendo Switch Pro Controller Joystick Caps Replacement, Open the flap: adım 9, 2 resimden 2.
    • Use the tip of an opening pick to open the black flap of the ZIF connector by pushing it upwards.
    FixBot'a Sor
    Yorum Ekle
  10. Nintendo Switch Pro Controller Joystick Caps Replacement, Disconnect the interconnect cable: adım 10, 2 resimden 1. Nintendo Switch Pro Controller Joystick Caps Replacement, Disconnect the interconnect cable: adım 10, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Use your fingers or a pair of blunt nose tweezers to disconnect the interconnect cable from its connector.
    FixBot'a Sor
    Yorum Ekle
  11. Nintendo Switch Pro Controller Joystick Caps Replacement, Remove the front case: adım 11, 1 resimden 1.
    • Remove the front case.
    FixBot'a Sor
    Yorum Ekle
  12. Nintendo Switch Pro Controller Joystick Caps Replacement, Remove the joystick caps: adım 12, 3 resimden 1. Nintendo Switch Pro Controller Joystick Caps Replacement, Remove the joystick caps: adım 12, 3 resimden 2. Nintendo Switch Pro Controller Joystick Caps Replacement, Remove the joystick caps: adım 12, 3 resimden 3.
    • With light force pull the two joystick caps off of the controller.
    FixBot'a Sor
    Yorum Ekle
Sonuç
33 farklı kişi bu kılavuzu tamamladı.
Ekip
Cal Poly, Team S11-G2, Regan Fall 2019 Cal Poly, Team S11-G2, Regan Fall 2019 üyesi
CPSU-REGAN-F19S11G2
5 Üyeler
45 adet Kılavuz yazıldı
3Kılavuz Yorumları
Where can I get the replacement caps?
Locke Valentine - Yanıt Paylaş
do you know where to find a replacement cap? If so can you give me link, thanks!
Jesus Acosta - Yanıt Paylaş
You really don't need to disconnect the ZIF to replace the caps. It might make things a tiny bit easier, but is best not to mess with it AT ALL if you're only replacing the caps. As messing it up, or not connecting it properly when you're putting it back together can lead to ALL your face buttons and D-pad not working.
master2873 - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 17
Son 7 gün: 120
Son 30 gün: 642
Her zaman: 33,946
