Ana içeriğe geç
Nintendo Switch Pro Controller Trigger Button Replacement
Neye ihtiyacın var
  1. Nintendo Switch Pro Controller Trigger Button  Replacement, Remove the screws: adım 1, 1 resimden 1.
    • Flip the controller over so the model stickers face the ceiling.
    • Use a JIS #00 screwdriver to remove the two black 8.4 mm screws that secure the handles, located at the ends of the handles.
    FixBot'a Sor
    Yorum Ekle
  2. Nintendo Switch Pro Controller Trigger Button  Replacement, Remove the handle covers: adım 2, 3 resimden 1. Nintendo Switch Pro Controller Trigger Button  Replacement, Remove the handle covers: adım 2, 3 resimden 2. Nintendo Switch Pro Controller Trigger Button  Replacement, Remove the handle covers: adım 2, 3 resimden 3.
    • Carefully remove the handle covers by pulling them away from the main body.
    FixBot'a Sor
    Yorum Ekle
  3. Nintendo Switch Pro Controller Trigger Button  Replacement, Remove the screws: adım 3, 1 resimden 1.
    • Use a JIS #00 screwdriver to remove the four silver 6.8 mm screws that secure the clear back plastic cover.
    FixBot'a Sor
    Yorum Ekle
  4. Nintendo Switch Pro Controller Trigger Button  Replacement, Unclip the plastic cover: adım 4, 3 resimden 1. Nintendo Switch Pro Controller Trigger Button  Replacement, Unclip the plastic cover: adım 4, 3 resimden 2. Nintendo Switch Pro Controller Trigger Button  Replacement, Unclip the plastic cover: adım 4, 3 resimden 3.
    • Carefully pry away the clear plastic cover using your fingernail.
    FixBot'a Sor
    Yorum Ekle
  5. Nintendo Switch Pro Controller Trigger Button  Replacement, Remove the clear plastic cover: adım 5, 1 resimden 1.
    • Remove the clear plastic cover.
    FixBot'a Sor
    Yorum Ekle
  6. Nintendo Switch Pro Controller Trigger Button  Replacement, Remove the battery: adım 6, 3 resimden 1. Nintendo Switch Pro Controller Trigger Button  Replacement, Remove the battery: adım 6, 3 resimden 2. Nintendo Switch Pro Controller Trigger Button  Replacement, Remove the battery: adım 6, 3 resimden 3.
    • Remove the lithium-ion battery by using a fingernail or plastic opening tool to pry it up on the left side.
    • Only a small amount of force is needed.
    FixBot'a Sor
    Yorum Ekle
  7. Nintendo Switch Pro Controller Trigger Button  Replacement, Remove the screws: adım 7, 3 resimden 1. Nintendo Switch Pro Controller Trigger Button  Replacement, Remove the screws: adım 7, 3 resimden 2. Nintendo Switch Pro Controller Trigger Button  Replacement, Remove the screws: adım 7, 3 resimden 3.
    • Use a Phillips #1 screwdriver to remove the five 5 mm screws from the back of the controller.
    • The two case screws above the handgrips and the single case screw below the battery bay have a shallow seat. These three screws can be easily removed.
    • The two case screws adjacent to the ZR and ZL shoulder buttons have a deep seat. Use an extension or a narrow PH1 Phillips screwdriver with a longer shaft to reach these screws.
    FixBot'a Sor
    Yorum Ekle
  8. Nintendo Switch Pro Controller Trigger Button  Replacement: adım 8, 3 resimden 1. Nintendo Switch Pro Controller Trigger Button  Replacement: adım 8, 3 resimden 2. Nintendo Switch Pro Controller Trigger Button  Replacement: adım 8, 3 resimden 3.
    • There's an adhesive pad located in the center of each handle. It will require a bit of force to pry away the front cover, but be mindful of the attached ribbon cable.
    • Delicately take off the plastic cover from the controller.
    • Don't completely remove the front cover just yet, as it's still attached to the motherboard via a white ribbon cable.
    FixBot'a Sor
    Yorum Ekle
  9. Nintendo Switch Pro Controller Trigger Button  Replacement, Open the flap: adım 9, 2 resimden 1. Nintendo Switch Pro Controller Trigger Button  Replacement, Open the flap: adım 9, 2 resimden 2.
    • Use the tip of an opening pick to open the black flap of the ZIF connector by pushing it upwards.
    FixBot'a Sor
    Yorum Ekle
  10. Nintendo Switch Pro Controller Trigger Button  Replacement, Disconnect the interconnect cable: adım 10, 2 resimden 1. Nintendo Switch Pro Controller Trigger Button  Replacement, Disconnect the interconnect cable: adım 10, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Use your fingers or a pair of blunt nose tweezers to disconnect the interconnect cable from its connector.
    FixBot'a Sor
    Yorum Ekle
  11. Nintendo Switch Pro Controller Trigger Button  Replacement, Remove the front case: adım 11, 1 resimden 1.
    • Remove the front case.
    FixBot'a Sor
    Yorum Ekle
  12. Nintendo Switch Pro Controller Trigger Button  Replacement, Remove the screws: adım 12, 1 resimden 1.
    • Remove the two 6.8 mm-long screws on the top circuit board using a Phillips screwdriver.
    FixBot'a Sor
    Yorum Ekle
  13. Nintendo Switch Pro Controller Trigger Button  Replacement, Open the ZIF connector: adım 13, 2 resimden 1. Nintendo Switch Pro Controller Trigger Button  Replacement, Open the ZIF connector: adım 13, 2 resimden 2.
    • Use a spudger to flip up the locking tab on the ZIF connector.
    FixBot'a Sor
    Yorum Ekle
  14. Nintendo Switch Pro Controller Trigger Button  Replacement: adım 14, 2 resimden 1. Nintendo Switch Pro Controller Trigger Button  Replacement: adım 14, 2 resimden 2.
    • Remove the black ribbon cable from its connector.
    • Only a small amount of force should be needed to remove the ribbon cable.
    FixBot'a Sor
    Yorum Ekle
  15. Nintendo Switch Pro Controller Trigger Button  Replacement: adım 15, 2 resimden 1. Nintendo Switch Pro Controller Trigger Button  Replacement: adım 15, 2 resimden 2.
    • Remove the trigger buttons from the plastic cover.
    FixBot'a Sor
    Yorum Ekle
Sonuç
16 farklı kişi bu kılavuzu tamamladı.
Simon Lin
434 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S11-G2, Regan Fall 2019 Cal Poly, Team S11-G2, Regan Fall 2019 üyesi
CPSU-REGAN-F19S11G2
5 Üyeler
45 adet Kılavuz yazıldı
7Kılavuz Yorumları
This guide does show how to remove the trigger/bumper casing and board from the controller but does not show how to remove the triggers/bumpers from the casing they are in.
Boushi Adams - Yanıt Paylaş
Yeah, this is a pretty big point to be missing, especially with the Flex Cable for the shoulder button inputs being right beside the post you need to pull out to remove the ZL and ZR buttons. Guidance on how to remove the post safely without damaging the cable would be great.
Alex Crocker - Yanıt Paylaş
Used the guide to repair a shattered right shoulder button successfully. Thanks!
Christian - Yanıt Paylaş
After reinstalling the shoulder buttons I have found them to stop working, all four, I checked my ribbon cable from the buttons to the board and even replaced it. I also confirmed the ribbon cable connector on the main board is working as well. Can anyone make any further troubleshooting suggestions?
David - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 20
Son 7 gün: 97
Son 30 gün: 536
Her zaman: 58,622
