Ana içeriğe geç
Nintendo Switch Right Joy-Con Shell Replacement
Neye ihtiyacın var
  1. Nintendo Switch Right Joy-Con Shell Replacement, Right Joy-Con Shell: adım 1, 1 resimden 1.
    • Remove the 4 tri-point screws on the back of the Joy-Con.
    • These are the only tri-point screws on the Joy-Con. All other screws require a Phillips head screwdriver.
    • These screws are incredibly easy to strip. Apply constant downward pressure while unscrewing them.
    FixBot'a Sor
    Yorum Ekle
  2. Nintendo Switch Right Joy-Con Shell Replacement: adım 2, 1 resimden 1.
    • Flip open the back shell to expose the battery.
    FixBot'a Sor
    Yorum Ekle
  3. Nintendo Switch Right Joy-Con Shell Replacement: adım 3, 2 resimden 1. Nintendo Switch Right Joy-Con Shell Replacement: adım 3, 2 resimden 2.
    • Remove the screw connecting the rail to the back shell.
    FixBot'a Sor
    Yorum Ekle
  4. Nintendo Switch Right Joy-Con Shell Replacement: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Remove the battery and disconnect it from the motherboard. You may use tweezers or your hands to pull connections from the motherboard.
    • The battery may be difficult to remove due to adhesive. A spudger may help to detach it from the casing.
    FixBot'a Sor
    Yorum Ekle
  5. Nintendo Switch Right Joy-Con Shell Replacement: adım 5, 2 resimden 1. Nintendo Switch Right Joy-Con Shell Replacement: adım 5, 2 resimden 2.
    • Before performing the next step, take note of how the antenna cable is seated for proper reassembly.
    • Remove the small antenna chip (shown in second picture) and disconnect it from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  6. Nintendo Switch Right Joy-Con Shell Replacement: adım 6, 1 resimden 1.
    • Remove the 3 screws holding the battery casing in the shell.
    FixBot'a Sor
    Yorum Ekle
  7. Nintendo Switch Right Joy-Con Shell Replacement: adım 7, 3 resimden 1. Nintendo Switch Right Joy-Con Shell Replacement: adım 7, 3 resimden 2. Nintendo Switch Right Joy-Con Shell Replacement: adım 7, 3 resimden 3.
    • Remove the ribbon cables connecting the rail and battery casing to the motherboard. Unlock the cables by flipping the connector upwards with a spudger, then pull the cable out of the connector.
    • You may even choose to leave the rail connected, though it will be unwieldy.
    • Be careful not to lift the connectors in the wrong direction. The connection nearest to the shoulder buttons lifts up away from the rail (the black part), and the connection nearest to the rumble motor lifts in the opposite direction, up toward the rail (the thin grey part.)
    FixBot'a Sor
    Yorum Ekle
  8. Nintendo Switch Right Joy-Con Shell Replacement: adım 8, 3 resimden 1. Nintendo Switch Right Joy-Con Shell Replacement: adım 8, 3 resimden 2. Nintendo Switch Right Joy-Con Shell Replacement: adım 8, 3 resimden 3.
    • Remove the rumble motor by disconnecting the white 2-pin connector.
    FixBot'a Sor
    Yorum Ekle
  9. Nintendo Switch Right Joy-Con Shell Replacement: adım 9, 3 resimden 1. Nintendo Switch Right Joy-Con Shell Replacement: adım 9, 3 resimden 2. Nintendo Switch Right Joy-Con Shell Replacement: adım 9, 3 resimden 3.
    • Remove the black ZR button from the battery casing.
    • Remove the button sensor by unscrewing it from the battery casing.
    FixBot'a Sor
    Yorum Ekle
  10. Nintendo Switch Right Joy-Con Shell Replacement: adım 10, 2 resimden 1. Nintendo Switch Right Joy-Con Shell Replacement: adım 10, 2 resimden 2.
    • Remove the two Phillips screws holding the joystick to the motherboard.
    • Disconnect the joystick ribbon cable from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  11. Nintendo Switch Right Joy-Con Shell Replacement: adım 11, 2 resimden 1. Nintendo Switch Right Joy-Con Shell Replacement: adım 11, 2 resimden 2.
    • Remove the two screws anchoring the motherboard to the shell.
    FixBot'a Sor
    Yorum Ekle
  12. Nintendo Switch Right Joy-Con Shell Replacement: adım 12, 1 resimden 1.
    • Transfer all buttons to the replacement shell.
    • If any silicone button covers are missing, they may be stuck to the back of the motherboard.
    FixBot'a Sor
    Yorum Ekle
Sonuç
71 farklı kişi bu kılavuzu tamamladı.
9Kılavuz Yorumları
Not quite as thorough as the other Joy-con tear down but always a handy thing to have, going by the pictures it gave me all the information I needed personally concerning the screws, so I was able to strip the whole controller down and swap it into another shell. It is straight forward once you get in to it and have to give the author their much deserved credit for posting this up!
Lee Whittaker - Yanıt Paylaş
Very good detailed guide, only thing I would change is I’d probably take the rumble motor out right after of even before the battery. It’s pretty easy to remove, you can do it at anytime after opening, and it gets the wires out of the way to make other parts easier.
Dominic Garcia - Yanıt Paylaş
I am having difficulty removing the ribbon cable next to the rumble motor on step 7. It would be nice to have a photo of which way the clamp is expected to swing; I suspect I know the correct direction, but my tools are bending it instead.
earthexe - Yanıt Paylaş
In fact, this step is unnecessary unless you are replacing the buttons or rail case. The rail may remain attached if you are only replacing the front, back, and middle casing.
*attention* the r button can be very easily broken off when removing the pcb. It requires soldering skills to re attach it afterward.
Tthat1guy - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 55
Son 7 gün: 189
Son 30 gün: 938
Her zaman: 111,614
