Ana içeriğe geç
Nintendo Switch LCD Replacement
Neye ihtiyacın var
  1. Nintendo Switch LCD Replacement, Release the Joy Con controller locking tabs: adım 1, 3 resimden 1. Nintendo Switch LCD Replacement, Release the Joy Con controller locking tabs: adım 1, 3 resimden 2. Nintendo Switch LCD Replacement, Release the Joy Con controller locking tabs: adım 1, 3 resimden 3.
    • Before you begin this repair, make sure the device is completely powered off.
    • Press and hold down the small round button on the back of the Joy Con controller.
    • While you hold down the button, slide the controller upward.
  2. Nintendo Switch LCD Replacement, Remove the Joy Con controllers: adım 2, 3 resimden 1. Nintendo Switch LCD Replacement, Remove the Joy Con controllers: adım 2, 3 resimden 2. Nintendo Switch LCD Replacement, Remove the Joy Con controllers: adım 2, 3 resimden 3.
    • Continue sliding the Joy Con upward until it's completely removed from the console.
    • Repeat this same process for the other Joy Con.
  3. Nintendo Switch LCD Replacement, Remove the back-side screws: adım 3, 1 resimden 1.
    Bu adımda kullanılan alet:
    Magnetic Project Mat
    $19.95
    Satın Al
    • Use a Y00 screwdriver to remove the four 6.3 mm-long screws securing the rear panel.
  4. Nintendo Switch LCD Replacement, Remove the top and bottom screws: adım 4, 2 resimden 1. Nintendo Switch LCD Replacement, Remove the top and bottom screws: adım 4, 2 resimden 2.
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the following screws securing the rear panel:
    • One 2.5 mm-long screw on the top edge of the device
    • Two 2.5 mm-long screws on the bottom edge of the device
    • To prevent these tight screws from stripping, apply firm downward force, work slowly and try another JIS 000 or PH 000 driver if the screws won't come out.
  5. Nintendo Switch LCD Replacement: adım 5, 2 resimden 1. Nintendo Switch LCD Replacement: adım 5, 2 resimden 2.
    • Use a JIS 000 screwdriver or an official iFixit PH 000 driver to remove the two 3.8 mm center screws on the sides of the device (one on each side).
  6. Nintendo Switch LCD Replacement: adım 6, 2 resimden 1. Nintendo Switch LCD Replacement: adım 6, 2 resimden 2.
    • Use your finger to flip up the kickstand on the back of the device.
    • If there's a microSD card in the microSD card slot, remove it now before you continue to the next step.
  7. Nintendo Switch LCD Replacement: adım 7, 1 resimden 1.
    • Use a JIS 000 screwdriver or an official iFixit PH 000 driver to remove the 1.6 mm screw in the kickstand well.
    • Close the kickstand.
  8. Nintendo Switch LCD Replacement: adım 8, 3 resimden 1. Nintendo Switch LCD Replacement: adım 8, 3 resimden 2. Nintendo Switch LCD Replacement: adım 8, 3 resimden 3.
    • Open the game card cartridge flap.
    • The game card cartridge flap attaches to the other half of the plastic shell, preventing you from completely lifting up the rear panel if it's closed.
    • Lift the rear panel up from the bottom of the device and remove it.
  9. Nintendo Switch LCD Replacement, Remove the microSD card reader: adım 9, 1 resimden 1.
    • Use a JIS 000 screwdriver or an official iFixit PH 000 driver to remove the 3.1 mm screw securing the microSD card reader to the device.
  10. Nintendo Switch LCD Replacement: adım 10, 2 resimden 1. Nintendo Switch LCD Replacement: adım 10, 2 resimden 2.
    • Use your fingers or a pair of tweezers to lift the microSD card reader straight up from the device to disconnect and remove it.
    • During reassembly, make sure the press connector underneath the foam pad is firmly connected to the motherboard. It may help to remove the foam pad before reinstalling the card reader.
  11. Nintendo Switch LCD Replacement, Remove the shield plate: adım 11, 1 resimden 1.
    • Use a JIS 000 screwdriver or an official iFixit PH 000 driver to remove the six 3 mm screws securing the shield plate to the device.
  12. Nintendo Switch LCD Replacement: adım 12, 2 resimden 1. Nintendo Switch LCD Replacement: adım 12, 2 resimden 2.
    • Use your fingers or a pair of tweezers to peel back the piece of foam on the top edge of the device near the fan exhaust port.
    • If the foam doesn't easily peel away, don't force it as it might end up tearing. Carefully peel at different spots to pull back the foam.
  13. Nintendo Switch LCD Replacement: adım 13, 3 resimden 1. Nintendo Switch LCD Replacement: adım 13, 3 resimden 2. Nintendo Switch LCD Replacement: adım 13, 3 resimden 3.
    • Insert a spudger underneath the shield plate along the edge of the device.
    • Pry up to lift the shield plate and remove it from the device.
    • You may feel a bit of resistance. This is normal, since the shield plate is slightly bonded to the heat sink with thermal paste.
    • A thick pink thermal compound bridges the gap between the shield plate and the copper heat sink underneath. This helps prevent the Switch from overheating.
    • You can reuse the pink thermal compound if you're careful. Keep the compound clean and make sure it makes solid contact between the heat sink and the shield during reassembly.
    • If you need to replace it, refer to our thermal paste guide to remove the old thermal compound and replace it with an appropriate compound, such as K5 Pro, during reassembly.
  14. Nintendo Switch LCD Replacement, Disconnect the battery: adım 14, 2 resimden 1. Nintendo Switch LCD Replacement, Disconnect the battery: adım 14, 2 resimden 2.
    • Use the point of a spudger to pry the battery connector straight up and out of its socket on the motherboard.
  15. Nintendo Switch LCD Replacement, Remove the heat sink: adım 15, 1 resimden 1.
    • Use a JIS 000 screwdriver or an official iFixit PH 000 driver to remove the three 3 mm screws securing the heat sink to the motherboard.
    • Carefully peel the two foam pieces stuck over both the heatsink and the fan away from the fan.
    • The foam only needs to be peeled back enough to clear the fan.
    • The foam is really delicate and tears easily. Use the following technique to peel the foam:
    • Insert the point of a spudger underneath the part of the foam that isn't stuck against anything,
    • Press the top of the foam with your finger to hold it in place.
    • Roll the spudger tip underneath the foam all the way to the other end of the foam to release it.
  16. Nintendo Switch LCD Replacement: adım 17, 3 resimden 1. Nintendo Switch LCD Replacement: adım 17, 3 resimden 2. Nintendo Switch LCD Replacement: adım 17, 3 resimden 3.
    • Use a spudger or your fingers to lift the heatsink up and off the motherboard to remove it.
    • You may feel a bit of resistance. This is normal, since the heat sink is slightly bonded to the CPU with thermal paste.
    • Clean off the old thermal paste from the heat sink and CPU using high-concentration (90% or higher) isopropyl alcohol and a microfiber cloth. Apply new thermal paste to the CPU before reassembly.
    • Apply thermal paste to all surfaces that had thermal paste applied previously. This includes between the heatpipe and aluminum shield, which the Switch uses as additional heatsinking.
  17. Nintendo Switch LCD Replacement, Remove the headphone jack and game card reader: adım 18, 2 resimden 1. Nintendo Switch LCD Replacement, Remove the headphone jack and game card reader: adım 18, 2 resimden 2.
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the digitizer cable's ZIF connector.
  18. Nintendo Switch LCD Replacement: adım 19, 2 resimden 1. Nintendo Switch LCD Replacement: adım 19, 2 resimden 2.
    • Use a pair of tweezers to slide the digitizer cable horizontally out of its connector on the game card reader board.
    • Before inserting the cable during reassembly, make sure the ZIF connector locking flap is flipped up.
    • With the cable parallel to the board, gently slide it into its connector.
    • Don't force the cable into the connector. If it doesn't insert, ensure the locking flap is flipped up, reposition the cable, and try again.
    • If your touchscreen doesn't work after the repair but your Game Card reader does, make sure this cable is properly inserted. If your Game Card reader also doesn't work, check the Game Card connector in the next step instead.
  19. Nintendo Switch LCD Replacement: adım 20, 2 resimden 1. Nintendo Switch LCD Replacement: adım 20, 2 resimden 2.
    • Use the point of a spudger to pry the headphone jack and game card reader connector straight up to disconnect it from the motherboard.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
    • If the touch screen doesn't work and/or game cards aren't detected after reassembly, you might have not fully reconnected this press connector. Carefully disconnect it and try again.
  20. Nintendo Switch LCD Replacement: adım 21, 1 resimden 1.
    • Use a JIS 000 screwdriver or an official iFixit PH 000 driver to remove the three 3.1 mm screws securing the headphone jack and game card reader board to the device.
  21. Nintendo Switch LCD Replacement: adım 22, 2 resimden 1. Nintendo Switch LCD Replacement: adım 22, 2 resimden 2.
    • Use a pair of tweezers or your fingers to remove the headphone jack bracket.
  22. Nintendo Switch LCD Replacement: adım 23, 2 resimden 1. Nintendo Switch LCD Replacement: adım 23, 2 resimden 2.
    • Use a pair of tweezers or your fingers to remove the headphone jack and game card reader board.
  23. Nintendo Switch LCD Replacement, Screen: adım 24, 2 resimden 1. Nintendo Switch LCD Replacement, Screen: adım 24, 2 resimden 2.
    • Use an opening tool, spudger, or your fingernail to flip up the small, hinged locking flap on the LCD ribbon cable ZIF connector.
  24. Nintendo Switch LCD Replacement: adım 25, 2 resimden 1. Nintendo Switch LCD Replacement: adım 25, 2 resimden 2.
    • Use a pair of tweezers to pull the ribbon cable straight out of its connector on the motherboard.
  25. Nintendo Switch LCD Replacement: adım 26, 2 resimden 1. Nintendo Switch LCD Replacement: adım 26, 2 resimden 2.
    • Use an opening tool, spudger, or your fingernail to flip up the small, hinged locking flap on the smaller LCD ribbon cable ZIF connector.
  26. Nintendo Switch LCD Replacement: adım 27, 2 resimden 1. Nintendo Switch LCD Replacement: adım 27, 2 resimden 2.
  27. Nintendo Switch LCD Replacement: adım 28, 1 resimden 1.
    • Heat an iOpener and apply it to the bottom edge of the screen for around two minutes to to help soften the adhesive.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device—the display and internal battery are both susceptible to heat damage.
  28. Nintendo Switch LCD Replacement: adım 29, 3 resimden 1. Nintendo Switch LCD Replacement: adım 29, 3 resimden 2. Nintendo Switch LCD Replacement: adım 29, 3 resimden 3.
    • Apply a suction cup to the bottom-left corner of the screen.
    • Pull up on the suction up with strong, steady force to create a gap.
    • Depending on the age of your device, this may be difficult. If you have trouble, apply more heat and try again.
    • Insert the point of an opening pick into the gap, making sure to only insert the pick about 5 mm.
  29. Nintendo Switch LCD Replacement: adım 30, 3 resimden 1. Nintendo Switch LCD Replacement: adım 30, 3 resimden 2. Nintendo Switch LCD Replacement: adım 30, 3 resimden 3.
    • Slide the opening pick along the bottom edge of the screen to slice the adhesive.
    • Leave the pick inserted to prevent the adhesive from re-adhering to the frame.
  30. Nintendo Switch LCD Replacement: adım 31, 3 resimden 1. Nintendo Switch LCD Replacement: adım 31, 3 resimden 2. Nintendo Switch LCD Replacement: adım 31, 3 resimden 3.
    • Insert a second opening pick into the gap to the left of the first pick.
    • Slide the opening pick back towards the left side of the device.
    • Leave the opening pick inserted.
  31. Nintendo Switch LCD Replacement: adım 32, 1 resimden 1.
    • Heat the left edge of the screen for around two minutes to help soften the adhesive.
  32. Nintendo Switch LCD Replacement: adım 33, 3 resimden 1. Nintendo Switch LCD Replacement: adım 33, 3 resimden 2. Nintendo Switch LCD Replacement: adım 33, 3 resimden 3.
    • Continue sliding the opening pick around the bottom-left corner to slice the adhesive.
  33. Nintendo Switch LCD Replacement: adım 34, 2 resimden 1. Nintendo Switch LCD Replacement: adım 34, 2 resimden 2.
    • Continue sliding the opening pick along the left edge of the screen to slice to adhesive.
  34. Nintendo Switch LCD Replacement: adım 35, 1 resimden 1.
    • Heat the top edge of the screen for around two minutes to help soften the adhesive.
  35. Nintendo Switch LCD Replacement: adım 36, 3 resimden 1. Nintendo Switch LCD Replacement: adım 36, 3 resimden 2. Nintendo Switch LCD Replacement: adım 36, 3 resimden 3.
    • Continue sliding the opening pick around the top-left corner of the screen to slice the adhesive.
  36. Nintendo Switch LCD Replacement: adım 37, 3 resimden 1. Nintendo Switch LCD Replacement: adım 37, 3 resimden 2. Nintendo Switch LCD Replacement: adım 37, 3 resimden 3.
    • Continue sliding the opening pick along the top edge of the screen to slice the adhesive.
  37. Nintendo Switch LCD Replacement: adım 38, 3 resimden 1. Nintendo Switch LCD Replacement: adım 38, 3 resimden 2. Nintendo Switch LCD Replacement: adım 38, 3 resimden 3.
    • Heat the right edge of the screen for around two minutes to help soften the adhesive.
    • Place the flat end of a spudger into the gap along the left edge of the screen.
    • Carefully and slowly lift the left edge of the screen, opening it like a book.
  38. Nintendo Switch LCD Replacement: adım 39, 3 resimden 1. Nintendo Switch LCD Replacement: adım 39, 3 resimden 2. Nintendo Switch LCD Replacement: adım 39, 3 resimden 3.
    • Lift the right edge of the screen straight off the device, threading the ribbon cables through the frame as you do so.
    • Take care not to snag any of the ribbon cables on the frame as you remove the screen.
    • You can reuse the screen adhesive if it is still sticky. Otherwise, replace the adhesive with double-sided tape such as Tesa tape.
  39. Nintendo Switch LCD Replacement, Separate the LCD panel and digitizer: adım 40, 1 resimden 1.
    • Heat the top edge of the screen assembly for around two minutes to help soften the adhesive holding the LCD panel to the digitizer.
  40. Nintendo Switch LCD Replacement: adım 41, 3 resimden 1. Nintendo Switch LCD Replacement: adım 41, 3 resimden 2. Nintendo Switch LCD Replacement: adım 41, 3 resimden 3.
    • Turn the screen assembly over.
    • Insert an opening pick in between the LCD panel and the digitizer at the top-left corner.
    • It doesn't matter how deep you insert the opening pick, but about 5 mm is enough to slice through all the adhesive.
    • You can slightly bend the digitizer to create a wider gap, but take care not to bend it too far to cause damage to the digitizer if you're reusing it.
    • Slide the opening pick along the top edge of the screen assembly to slice the adhesive.
  41. Nintendo Switch LCD Replacement: adım 42, 3 resimden 1. Nintendo Switch LCD Replacement: adım 42, 3 resimden 2. Nintendo Switch LCD Replacement: adım 42, 3 resimden 3.
  42. Nintendo Switch LCD Replacement: adım 43, 1 resimden 1.
    • Heat the left edge of the screen assembly for around two minutes to help soften the adhesive.
  43. Nintendo Switch LCD Replacement: adım 44, 2 resimden 1. Nintendo Switch LCD Replacement: adım 44, 2 resimden 2.
    • Insert and slide the opening pick along the left edge of the screen assembly to slice the adhesive.
  44. Nintendo Switch LCD Replacement: adım 45, 3 resimden 1. Nintendo Switch LCD Replacement: adım 45, 3 resimden 2. Nintendo Switch LCD Replacement: adım 45, 3 resimden 3.
    • Continue sliding the opening pick around the bottom-left corner of the screen assembly to slice the adhesive.
  45. Nintendo Switch LCD Replacement: adım 46, 1 resimden 1.
    • Heat the bottom edge of the screen assembly for around two minutes to help soften the adhesive.
  46. Nintendo Switch LCD Replacement: adım 47, 3 resimden 1. Nintendo Switch LCD Replacement: adım 47, 3 resimden 2. Nintendo Switch LCD Replacement: adım 47, 3 resimden 3.
    • Continue sliding the opening pick along the bottom edge to slice the adhesive.
  47. Nintendo Switch LCD Replacement: adım 48, 1 resimden 1.
    • Heat the right edge of the screen assembly for around two minutes to help soften the adhesive.
  48. Nintendo Switch LCD Replacement: adım 49, 2 resimden 1. Nintendo Switch LCD Replacement: adım 49, 2 resimden 2.
    • Insert the flat end of a spudger in between the LCD panel and the digitizer along the left edge of the screen assembly.
    • Carefully and slowly lift up the left side of the LCD panel, opening it like a book.
  49. Nintendo Switch LCD Replacement: adım 50, 3 resimden 1. Nintendo Switch LCD Replacement: adım 50, 3 resimden 2. Nintendo Switch LCD Replacement: adım 50, 3 resimden 3.
    • Continue lifting the LCD panel away from the digitizer to separate the two components.
    • The LCD ribbon cable is slightly adhered to the digitizer. If it doesn't remove easily, apply more heat to that area and try again.
  50. Nintendo Switch LCD Replacement, LCD: adım 51, 1 resimden 1.
Sonuç
Compare your new replacement part to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before installing.
If your new LCD panel doesn’t work properly after you boot up the device, turn it back off and disconnect and reconnect the battery connector.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch Answers community for help.
56 farklı kişi bu kılavuzu tamamladı.
Craig Lloyd
35.354 İtibar
82 adet Kılavuz yazıldı
13 Yorum
I need to buy a new frame for the switch not front or rear panel, where do i get one of these? the vent at the top is broken.
Andrew Hammond - Yanıt
You need the front panel. These are usually sold as a set of the front and back. When you do the replacement, make absolutely sure you transfer the translucent light guide (small piece of white plastic) and the adhesive speaker covers over. One good thing about this replacement is that you don’t have to remove the motherboard or even disconnect the joycon guide rails completely from the middle mounting panel. Take your time, and be very patient. This replacement means detaching the digitizer and screen.
If you can’t find the case here, you might be able to find it on Amazon.
Michael Mueller -
I thought this was going to be hard but compared to automotive this was cake thanks for the guidelines.
thungar_naughty - Yanıt
Can I use HY-883-4g CPU Thermal Paste Kit-6.5 W/MK CPU Paste instead of the K5-pro thermal paste? Are there other thermal paste recommendations? Thank you.
Ell Wiley - Yanıt
You can use any thermal paste, if you already got one. If you need to buy one, thek5 pro is our suggestion.
Daniele Carminati -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 125
Son 7 gün: 772
Son 30 gün: 3,673
Her zaman: 155,063
