Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
Giriş
Step by step in detail LCD only replacement
Video talimatları
Bitiş Çizgisi
18 farklı kişi bu kılavuzu tamamladı.
@HectorNavarroMX
1.811 İtibar
18 adet Kılavuz yazıldı
5 Yorum
Was wondering what size of adhesive strips is being used?
Nicole Lewis - Yanıt
At 4:00 minute in the video he just starts prying open the screen. I don’t get this step as it is not clear where exactly he starts.
Gabriel Lozano-Moran - Yanıt
Once the ribbon cables are detached all that’s left is to warm up the adhesive holding the digitizer so you can remove it and the LCD. You can start where ever you please but DO NOT a spunger or pick on the same side as the cables. Work on the other 3 sides of the screen and then use the leverage of the screen to remove the digitizer + LCD together from the adhesive holding it to the system.
Kyle Collins -
I need to buy a new frame for the switch not front or rear panel, where do i get one of these? the vent at the top is broken.
Andrew Hammond - Yanıt
You need the front panel. These are usually sold as a set of the front and back. When you do the replacement, make absolutely sure you transfer the translucent light guide (small piece of white plastic) and the adhesive speaker covers over. One good thing about this replacement is that you don’t have to remove the motherboard or even disconnect the joycon guide rails completely from the middle mounting panel. Take your time, and be very patient. This replacement means detaching the digitizer and screen.
If you can’t find the case here, you might be able to find it on Amazon.
Michael Mueller -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 39
Son 7 gün: 361
Son 30 gün: 1,478
Her zaman: 17,723
