Ana içeriğe geç
Nintendo WaveBird Wireless Controller Channel Wheel Replacement
Neye ihtiyacın var
    1. Nintendo WaveBird Wireless Controller Channel Wheel Replacement, Batteries: adım 1, 2 resimden 1. Nintendo WaveBird Wireless Controller Channel Wheel Replacement, Batteries: adım 1, 2 resimden 2.
      • Pull down on the battery cover release lever and pull back to remove the cover.
      FixBot'a Sor
      Yorum Ekle
    2. Nintendo WaveBird Wireless Controller Channel Wheel Replacement: adım 2, 1 resimden 1.
      • Remove both batteries from the device.
      FixBot'a Sor
      Yorum Ekle
    1. Nintendo WaveBird Wireless Controller Channel Wheel Replacement, Front Panel: adım 3, 2 resimden 1. Nintendo WaveBird Wireless Controller Channel Wheel Replacement, Front Panel: adım 3, 2 resimden 2.
      • Remove the eight 9 mm screws from the back panel using the Tri-point Y1 screwdriver.
      • During reassembly, firmly hold the panels of the controller together while replacing the screws so the panels do not separate.
      FixBot'a Sor
      Yorum Ekle
    2. Nintendo WaveBird Wireless Controller Channel Wheel Replacement: adım 4, 2 resimden 1. Nintendo WaveBird Wireless Controller Channel Wheel Replacement: adım 4, 2 resimden 2.
      • Carefully turn over the controller and place it on a flat surface.
      • Slowly separate the top panel from the bottom panel.
      • The buttons are loose and may fall off the motherboard.
      • Once separated, set aside the top panel.
      • During reassembly, make sure the front panel lines up with the buttons so they slide back into place.
      FixBot'a Sor
      Yorum Ekle
    1. Nintendo WaveBird Wireless Controller Channel Wheel Replacement, Buttons: adım 5, 3 resimden 1. Nintendo WaveBird Wireless Controller Channel Wheel Replacement, Buttons: adım 5, 3 resimden 2. Nintendo WaveBird Wireless Controller Channel Wheel Replacement, Buttons: adım 5, 3 resimden 3.
      Bu adımda kullanılan alet:
      • Use tweezers to remove the buttons.
      • It may be easier to remove the A button off of the pad by lifting it with your fingers.
      • During reassembly, make sure all buttons are in their respective sockets so they match up with the front panel.
      FixBot'a Sor
      Yorum Ekle
    1. Nintendo WaveBird Wireless Controller Channel Wheel Replacement, Motherboard: adım 6, 1 resimden 1.
      • Using tweezers remove the three grey button pads from the motherboard.
      FixBot'a Sor
      Yorum Ekle
    2. Nintendo WaveBird Wireless Controller Channel Wheel Replacement: adım 7, 1 resimden 1.
      • With your fingers gently grip the motherboard on both sides and lift it away from the back panel.
      • To put the motherboard back into place, align the two metal clips under the motherboard with the slots in the back panel. The motherboard should fall into place.
      FixBot'a Sor
      Yorum Ekle
    1. Nintendo WaveBird Wireless Controller Channel Wheel Replacement, Channel Wheel: adım 8, 1 resimden 1.
      • Turn the motherboard over so the channel wheel is facing up.
      FixBot'a Sor
      Yorum Ekle
    2. Nintendo WaveBird Wireless Controller Channel Wheel Replacement: adım 9, 2 resimden 1. Nintendo WaveBird Wireless Controller Channel Wheel Replacement: adım 9, 2 resimden 2.
      • Pinch the wheel and pull it away from the motherboard.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Travis Taylor
554 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 10-40, Amido Spring 2013 Cal Poly, Team 10-40, Amido Spring 2013 üyesi
CPSU-AMIDO-S13S10G40
4 Üyeler
128 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 15
Son 30 gün: 39
Her zaman: 2,786
