Ana içeriğe geç
Nintendo WaveBird Wireless Controller Front Panel Replacement
Neye ihtiyacın var
  1. Nintendo WaveBird Wireless Controller Front Panel Replacement, Batteries: adım 1, 2 resimden 1. Nintendo WaveBird Wireless Controller Front Panel Replacement, Batteries: adım 1, 2 resimden 2.
    • Pull down on the battery cover release lever and pull back to remove the cover.
  2. Nintendo WaveBird Wireless Controller Front Panel Replacement: adım 2, 1 resimden 1.
    • Remove both batteries from the device.
  3. Nintendo WaveBird Wireless Controller Front Panel Replacement, Front Panel: adım 3, 2 resimden 1. Nintendo WaveBird Wireless Controller Front Panel Replacement, Front Panel: adım 3, 2 resimden 2.
    • Remove the eight 9 mm screws from the back panel using the Tri-point Y1 screwdriver.
    • During reassembly, firmly hold the panels of the controller together while replacing the screws so the panels do not separate.
  4. Nintendo WaveBird Wireless Controller Front Panel Replacement: adım 4, 2 resimden 1. Nintendo WaveBird Wireless Controller Front Panel Replacement: adım 4, 2 resimden 2.
    • Carefully turn over the controller and place it on a flat surface.
    • Slowly separate the top panel from the bottom panel.
    • The buttons are loose and may fall off the motherboard.
    • Once separated, set aside the top panel.
    • During reassembly, make sure the front panel lines up with the buttons so they slide back into place.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
JT Gryder
114 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 10-40, Amido Spring 2013 Cal Poly, Team 10-40, Amido Spring 2013 üyesi
CPSU-AMIDO-S13S10G40
4 Üyeler
37 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 48
Her zaman: 1,872
