Ana içeriğe geç
Nintendo WaveBird Wireless Controller Front Panel Replacement
Neye ihtiyacın var
    1. Nintendo WaveBird Wireless Controller Front Panel Replacement, Batteries: adım 1, 2 resimden 1. Nintendo WaveBird Wireless Controller Front Panel Replacement, Batteries: adım 1, 2 resimden 2.
      • Pull down on the battery cover release lever and pull back to remove the cover.
      FixBot'a Sor
      Yorum Ekle
    2. Nintendo WaveBird Wireless Controller Front Panel Replacement: adım 2, 1 resimden 1.
      • Remove both batteries from the device.
      FixBot'a Sor
      Yorum Ekle
    1. Nintendo WaveBird Wireless Controller Front Panel Replacement, Front Panel: adım 3, 2 resimden 1. Nintendo WaveBird Wireless Controller Front Panel Replacement, Front Panel: adım 3, 2 resimden 2.
      • Remove the eight 9 mm screws from the back panel using the Tri-point Y1 screwdriver.
      • During reassembly, firmly hold the panels of the controller together while replacing the screws so the panels do not separate.
      FixBot'a Sor
      Yorum Ekle
    2. Nintendo WaveBird Wireless Controller Front Panel Replacement: adım 4, 2 resimden 1. Nintendo WaveBird Wireless Controller Front Panel Replacement: adım 4, 2 resimden 2.
      • Carefully turn over the controller and place it on a flat surface.
      • Slowly separate the top panel from the bottom panel.
      • The buttons are loose and may fall off the motherboard.
      • Once separated, set aside the top panel.
      • During reassembly, make sure the front panel lines up with the buttons so they slide back into place.
      FixBot'a Sor
      Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
JT Gryder
117 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 10-40, Amido Spring 2013 Cal Poly, Team 10-40, Amido Spring 2013 üyesi
CPSU-AMIDO-S13S10G40
4 Üyeler
114 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 15
Son 30 gün: 47
Her zaman: 2,144
