Giriş
Use this guide to replace your Wii's Bluetooth board. Replacing the Bluetooth board requires removal of most components inside the Wii.
Neye ihtiyacın var
Use a metal spudger to remove the white plastic screw covers stuck to the lower case near the front of the Wii.
Open the controller port cover until it is perpendicular to the black controller port bezel.
Pull the controller port cover straight up to release it from the outer case.
Remove the small Phillips screw securing the battery door to the bottom panel.
Pull the battery door out of the Wii.
Use a pair of tweezers to lift the fan connector up and out of its socket on the logic board.
Remove the three 10 mm Phillips screws securing the black bracket to the bottom panel near the front of the Wii.
Slightly lift the bracket and use your other hand to pull the retaining clip away from where the Wi-Fi antennas enter the motherboard sheild.
Remove the bracket from the Wii.
Use the flat end of a spudger or your fingertips to lift up the end of the Bluetooth board nearest the center of the motherboard.
Carefully peel the front edge of the Bluetooth board off the EMI foam attached to the motherboard.
Remove the Bluetooth board.
46 farklı kişi bu kılavuzu tamamladı.
9 Yorum
Fantastic write up. My wiimote sync'd right up.
